1975 z1 high speed wobble
- tanner
24 Jul 2008 16:33
what can i do to fix this problem when i get to higher speeds?
- MFolks
Re: 1975 z1 high speed wobble
24 Jul 2008 17:40
Speed wobbles can be very time consuming to track down. I would start with:
1. Are swing arm bushings worn to the point of replacement.
2. Correct tire pressure has a lot to do with this.
3. "cupping" of the front tire(looks like someone removed a teaspoon of rubber from the front tire)
4. Excessive wear in the steering head bearings.
5. Has the bike been dropped and is the frame straight?
6. Does the bike want to track anyway but straight when the bars are released for a short time?
7. Are the rear shocks worn out and have you replaced them before?
These are a few things to look at.
- KZ250LTD
24 Jul 2008 18:42
Plus:
Fork oil
Fork springs
Fork seals
New forks
Kidding of course, but Z1's have always been pretty well known for their interesting handling. I'd say your major things to look at would be new tires (if they're worn) + pressure, swing arm bushings, and steering bearings (I would suggest tapered roller bearings if you're going to be replacing them anyway)
Fork oil
Fork springs
Fork seals
New forks
79 KZ1000ST
Past:
Many.
Past:
Many.
- Calhoun
- Hayabusa= I ride to the strip club in flip flops
24 Jul 2008 19:52
Running Kenda tires will do it also. Mine looked loke a tire but did not act like it. I switched to dunlops.
80 IT175, 84 XL200, XT250, 95 ST1100 96 xr650l (30k miles),kz1000, KX250 97'
Last and most important 93 KX500.
- 1973Z
25 Jul 2008 06:57
The first after market accessory I bought for my new Z1 35 years ago was a Kawsaki OEM steering damper that fit perfectly on the brackets already on the bike from the factory. I guess it does the job because I have never had a problem with high speed wobbles.
