REAR LOWERING BLOCKS
- pg4827
09 Feb 2006 14:19
I WAS TOLD THAT IF I INSTALLED A LOWERING BLOCK ON MY REAR SHOCKS I WILL HAVE TO BUY A LONGER REAR BRAKE SUPPORT ARM. HAS ANY ONE HAD A PROBLEM WITH THE SHOCK RUBBING THE BRAKE CALIPER? I HAVE THE STOCK SWING ARM AND BRAKES. [1978 KZ1000 A2]:huh:
- wireman
Re: REAR LOWERING BLOCKS
09 Feb 2006 14:34
JUST SAY NO TO THOSE LOWERING BLOCKS,BUY A GOOD SET OF SHORTER SHOCKS OR TRYING ADJUSTING YOUR SHOCKS TO SOFTEST SETTINGB) GOODLUCK,HAPPY WRENCHING!
- arobsum
09 Feb 2006 15:27
not true. i have a set of lowering blocks (chromed) on my 77 kz1000. they look great and work great. no other mods needed. just put them on and go.
- wireman
09 Feb 2006 17:34
puts your shocks at weird angle they try and bind rather than compress,it also puts a lot of leverage on the brackets and the bolts that hold them on.:whistle: goodluck,happy wrenching.
- tfh903
09 Feb 2006 18:50
I agree with Arobsum.. Have lowering blocks (chromed) and shorter shocks set to softest (except when I'm packing a passenger).. no problems except that I had to raise the fender and reroute the tail light wires.
Why would you have to get a longer brake support rod? your not moving the axel!
- 79MKII
- Love Them Kaws!
09 Feb 2006 18:54
I just bolted a set onto my 78 Z1-R this summer and the caliper did hit the shock. It would not work without the longer brake arm. I found a really nice chrome brake arm on eBay so it worked out, but I did need the longer brake arm for sure. Most lowering kits only list the 900 with drum brakes because of the caliper interference. I can't say for the other bikes, but that's my story (and I'm stickin' to it!)
I'm also pretty sure I needed it for my '79 MKII but I can't remember for 100% sure on that one:blink:
The Kaw List:
- tfh903
09 Feb 2006 19:34
OOPS! I didn't realize we were talking caliper's, sorry.. MKII is right, I remember looking at my 77LDT1000 and didn't think that the lowering blocks would work. Next time it comes home I will have to check it out and see about making a longer brake arm.
- pg4827
09 Feb 2006 21:04
THANKS FOR THE ADVICE I AM GOING TO TRY SHORTER SHOCKS FIRST. IF IT IS NOT LOW ENOUGH I WILL BUY THE LOWERING BLOCK WITH A LONGER BRAKE SUPPORT ARM.
- wireman
10 Feb 2006 17:36
my 80 ltd page 2 of kz1000 gallery drags the header on the 2-3" speedbump in front of advance auto parts here in omaha,done strictly with shocks .i can measure the shocks if you want.:whistle:MEASURED SHOCKS 11 1/4 " WITH NO LOAD.
Post edited by: wireman, at: 2006/02/10 21:41
- pg4827
11 Feb 2006 05:39
I read a thread that a kz400 shocks wear used on a kz1000. They measure 11 1/4" bolt hole to bolt hole. I do not think I will have a draging problem sence my rear wheel is 18". What model shock and year did you use? And do you have a 16" rear wheel?
Post edited by: pg4827, at: 2006/02/11 08:42
Post edited by: pg4827, at: 2006/02/11 08:43
- wireman
11 Feb 2006 10:02
i believe mine are konis.im going to be pulling mine off and taking them apart to detail them in a few days ill let you know what they are then.
- pg4827
14 Mar 2006 09:12
I found a pair of new Harley 883 shocks (11.5") for $40. Lowered rear 2inch and know my feet are flat on the ground. I did have to remove rear finder and make a new support bracket for the licence plate. Also I cut the plastic chain guard so the shocks would not rub on it. It rides smoother than before but it does bottom out on big pot holes.
Post edited by: pg4827, at: 2006/03/14 12:18
