ZR7s Fork Swap
- saszta
ZR7s Fork Swap
09 Feb 2006 10:31
Hi, this question doesn't concern KZ's but it is for a Kawy so I thought someone around here may be able to help.
A buddy of mine hit a deer recently and mangled his front forks. Luckily he walked away with just some painful bruises. I believe the tripple clamp is damaged as well.
Do you know what forks can be swapped in place of what's originally stock on a 2002 ZR7s?
Can you just swap in a setup from a zx7?
Thanks for any replies.
- Snakebyte
Re: ZR7s Fork Swap
13 Feb 2006 07:46
I would check to see what bearings are interchangable. Then go from there. All you need to do is worry about lenth of the neck on your frame.
