78 KZ400B1 Master Cylinder Ideas or Replacement
  • boojr
  • boojr's Avatar Topic Author
20 Jul 2008 10:47
#227269
Have a 78 KZ400 B1 with a laeking front brake master cylinder. I took it all apart, cleaned it, and put back togather. Started to leak again around the dust cover. The rubber on the pluger is 30 years old and worn.
The problem is I can not find a rebuild kit for this model. On ebay, there are rebuild kits for the A1, but the cylinder is completely different.
Also, on eBay, they sell replacement cylinders for 50-70 bucks for the kz400. Though this would work, but the stated handlebar diameter is 7/8" and when I measure mine, it is 3/4".
Seeking help on rebiuld kit or good replacement. I would think that anythink replacement cyclinder would work with 3/4" handlebar. Only 1 disc, so most likely anything would be overkill.
Searched for about 45 minutes, but did not find any topic that dealt with the KZ400B1.
Here is the rebuild kit:
cgi.ebay.com/ebaymotors/MASTER-CYLINDER-...dZ1QQsspagenameZWDVW
Here is the replacement cylinder:
cgi.ebay.com/ebaymotors/FRONT-BRAKE-MAST...dZ1QQsspagenameZWDVW
74 XL250
78 KZ400B1
79 KZ650SR
84 V65 Sabre
06 VMAX
  • MFolks
  • MFolks's Avatar
Re: 78 KZ400B1 Master Cylinder Ideas or Replacement
20 Jul 2008 13:57
#227303
