wheel bearings
- bowana
wheel bearings
19 Jul 2008 15:05
I just recently got my 1982 LTD 1000 running after having acquired it from the previous owner a few weeks ago. I had to clean the tank and went with the Kreem liner, I also went through the carbs , brakes , new airbox boots etc. I was all happy until I took it foe a test ride and noticed some rear tire wobble. I got home and tore it down and the right rear bearing is ruined. I want to replace all of the bearings and seals but I was a little confused by the Z1 Enterprises info. Can anyone verify the part numbers necessary? Thanks.
Re: wheel bearings
19 Jul 2008 16:07
Part nos. are available for each different model on
www.Kawasaki.com
(and other sites). If needing some search tips, let us know. Good Luck! :)
- Bluemeanie
Re: wheel bearings
20 Jul 2008 05:52 - 20 Jul 2008 05:57
See if I can get this right.....here is the part diagram with part number listing.
Item Part Number Part Name Quantity K1 K2 Remarks
41068 41068-1087 AXLE,RR,L=300 1 1 1
41073 41073-1090 WHEEL-ASSY 1 1 1
42033 42033-1024 COUPLING-ASSY 1 1 1
42036 42041-1059 SPROCKET-HUB,39T 1 1 1
42041 42041-1059 SPROCKET-HUB,39T 1 1 1
92001 92001-161 BOLT 6 6 6
92015 42045-005 NUT 10MM 6 6 6
92015A 42045-018 NUT CASTLE,18MM 1 1 1
92022 92022-1212 WASHER,LOCK 3 3 3
92022A 92022-248 WASHER,PLAIN,20MM 1 1 1
92027 92027-1286 COLLAR,L=89.5 1 1 1
92027A 92027-1287 COLLAR,20X40X18 1 1 1
92027B 92027-1288 COLLAR,L=31 1 1 1
92033 92033-1043 RING,SNAP,56.2M/M 1 1 1
92033A 92033-1044 CIRCLIP,62M/M 1 1 1
92049 92049-1061 SEAL-OIL 1 1 1
92049A 92050-027 OIL SEAL 1 1 1
92057 92057-1053 DR CHAIN 630X96 1 1 1
92075 42014-033 SHOCK DAMPER,REAR HU 1 1 1
550 550D4035 PIN-COTTER,4.0X35 1 1 1
601 601B6206 BALL BEARING,#6206 1 1 1
601A 601B6304ZZ BEARING,BALL,#6304ZZ 2 2 2
671 671B2565 "0" RING,65MM 1 1 1
Last edit: 20 Jul 2008 05:57 by Bluemeanie.
- steell
Re: wheel bearings
20 Jul 2008 09:11
See where it says "BALL BEARING,#6206" and "BEARING,BALL,#6304ZZ" in the parts numbers? The "6206" and "6304ZZ" are generic part numbers that can be used to source the bearings at your local bearing supply house.
- retterath
Re: wheel bearings
21 Jul 2008 12:31
I just replaced all the bearings and seals in my rear wheel. Got the all-balls kit from DennisKirk. Pretty straight forward.
