Where to get master cylinder rebuild kits?
  • Sleepy
  • Sleepy's Avatar
Re: Where to get master cylinder rebuild kits?
09 Feb 2006 16:45
#22797
On the front it's not a bad idea - most master cylinders would work - you just have to try and match piston size to get the same lever action.
The rear is a different matter - it's a much tricker proposition to find one that'll bolt up and share the same linkage without modification.
kz650 gs750 cb750
  • storysunfolding
  • storysunfolding's Avatar Topic Author
09 Feb 2006 16:47
#22798
Oh to have the 81 KZ 650 CSR with it's drum rear brakes B)
Does anyone know a good master cylinder to swap out with teh front?
  • wireman
  • wireman's Avatar
11 Feb 2006 05:24
#23091
dual disk or single,what pison size?
  • storysunfolding
11 Feb 2006 08:45
#23121
Single disc and don't know.
  • fixer5000
  • fixer5000's Avatar
11 Feb 2006 16:34
#23201
what youve got is a 1/2 inch master there. i couldnt find a kit for mine either so im going to dual calipers and a 5/8 master. im pretty sure you can still get that part from kawasaki though. it will cost you more...good luck...steve
1978 kz650b pretty much stock
massachusetts
  • drayman86
  • drayman86's Avatar
19 Feb 2007 20:10
#113737
Hey group:
Found this thread searching for master cylinder re-build kits on the boards. Did anyone reach a conclusion about:
1. Front master cyl rebuild kit for KZ650 C?
2. Rear master cyl re-build kit for same?
Thanks!
  • Sputnic81
  • Sputnic81's Avatar
19 Feb 2007 20:20
#113741
I'm comparing apples to oranges a little bit--but...
I put the master from a 93 CBR F3 on my 440. Works like a dream, and get the added perk of having the adjustable lever. Plus it is already angled in case i decide to put on clip ons at some point.
  • OKC_Kent
  • OKC_Kent's Avatar
19 Feb 2007 21:04
#113760
drayman86 wrote:
Hey group:
Thanks!
If you have the trapezoid shaped master cylinder on your 650 then go to Redline Cycles at this link. I believe the last kit on the page will fit the 650 with the trapezoid shape master. That master was also used on some of the bigger Kaws, like the 1000 A2 I think.
tinyurl.com/36d9sd
I don't know about the rear master, sorry.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • dkmk
  • dkmk's Avatar
19 Feb 2007 21:10
#113763
Hey group:
Not sure about the rear, but I think the kit I used for the front of my '78 650C (triangular) was for a '77 or '78 KZ1000 A1/A2 (or '78-'79 A3/A4???). Can't remember which one, but it was 5/8 and it did work.
Post edited by: dkmk, at: 2007/02/20 00:11
Northern Ontario
Zapp: "Kif, I'm feeling the Captain's Itch."
Kif: "I'll get the powder, sir."
  • drayman86
20 Feb 2007 03:47
#113784
Thanks a lot, eh. B)
Did you get that kit from Parts 'N More? Looks just like the one they have for sale on their site.
Post edited by: drayman86, at: 2007/02/20 06:47
  • donthekawguy
  • donthekawguy's Avatar
20 Feb 2007 07:27
#113844
You can buy a new M/C on ebay for $40. Just type in kz1000 in the motorcycle parts section. There is a guy that sells them on there all the time. New and shiney without the mess and headache.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • drayman86
20 Feb 2007 16:14
#113957
Another long strange journey. Finding parts for a vintage bike restoration is one BF scavenger hunt, but it feels good when it pays off. (I've got a story about the search for a machine shop capable of doing a valve job, but that's in the Engine section.)
Master cylinder replacement piston for the REAR master on my 1978 KZ650 C2: FOUND. :laugh:
www.nwvintagecycleparts.com/index.php
This place is the BOMB. You can search their parts inventory by Kaw parts numbers from the schematics on the Kaw website. That's how I found the piston for the re-build on my rear master. They've got a great selection of Kaw parts and the folks are helpful.
Check 'em out.....
Post edited by: drayman86, at: 2007/02/21 15:02
