case guards
  • BSKZ650
  • BSKZ650's Avatar Topic Author
case guards
08 Feb 2006 18:09
#22594
just got a set of case guards for the kz1000, no hardware, but thats ok, anybody know were I can get the extra long bolts I need or maybe how much longer they need to be, looks like a 1/4 inch mounting , so I would guess a 1/2 inch longer would work, but just checking
Thanks
77 ltd1000, current rider
76 kz900, just waiting
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: case guards
08 Feb 2006 18:55
#22613
I used a piece of 7/16" all thread which I bought in Baker, Oregon while on a three day ride after the stock bolt gave up the ghost. It's held up for fifteen years, must be OK.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • tfh903
  • tfh903's Avatar
Re: case guards
11 Feb 2006 20:55
#23273
have you found the bolts yet?? I need some also for my AMEN frame. tfh when the weather clears up lets go riding
  • wireman
  • wireman's Avatar
Re: case guards
11 Feb 2006 21:50
#23284
try fastenal or other bolt supplier.B) goodluck,happy wrenching!
  • OKC_Kent
  • OKC_Kent's Avatar
Re: case guards
11 Feb 2006 22:13
#23289
When I put case guards on the 650 I could not find the right dia/length bolt combination in metric. I wound up using SAE, I think 3/8" ?? It was a hair smaller diameter but it had the right length. It sounds like the 1000 mounts are different if you can use all-thread.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • BSKZ650
Re: case guards
12 Feb 2006 06:26
#23311
I took the advice, went to a nut and bolt shop, bought a 7/16 SS allthread, SS nylock nuts and washers, had to ream out one of the brackets a bit to make it fit. Only needed 13 1/2 inches to make the new bolt
  • wireman
  • wireman's Avatar
Re: case guards
12 Feb 2006 07:56
#23319
im going to be making up some longer front motor mount bolts i can lengthen those long bolts that goe through the two front frame tubes they are a lot stronger than all-thread,you wont be able to tell they were lengthened but you will need to have them replated.anyone interested?you supply the origional bolt and pay for shipping.
