520 chain VS 530 chain on a KZ1000?
- cherrymetal
Re: 520 chain VS 530 chain on a KZ1000?
29 Jul 2008 23:55
What about a 525 chain? Thinking of putting one on my GPz750 engined KZ650 (engine stock at mo, but could get taken out to 810)
_____________________________________________________
1977 Z650 (WIP - GPz750 Engine, RF400 Wheels & brakes, Bandit 600 Forks, Zephyr Swingarm)
1997 ZRX1100 - Stock - for now!(except for Hindle header with Micron carbon can)
1988 NTV600 Revere - Stock (work hack!)
- 79MKII
- Love Them Kaws!
02 Aug 2008 21:32
This is an awesome thread! I just finished my MKII project and had to go with a 520 chain due to a 6" wide rear rim. Didn't want to do it, but I don't want to clearance the frame after it has been powder coated and the entire bike is together. Anyway, I got my 520 offset off eBay pretty cheap. I'll see if I can find some more info. They are definitely out there.
Badkaw - mine is now a 1260cc also - I hope the 520 holds up!!
The Kaw List:
- Old Man Rock
03 Aug 2008 07:48 - 03 Aug 2008 07:49
79MKII: "520 chain due to a 6" wide rear rim"
What's the offset in this sprocket (1/2)?
Or is this OEM of some other make where the spline teeth match with a couple of spacer washers (3/8-1/2)?
In the e-bay listing, they would have most likely posted what this CC sprocket came off of, Manufacturer, Year and Model.
BigBlockT, what did you end up doing?
Thanks,
OMR
Thanks,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 03 Aug 2008 07:49 by Old Man Rock.
- 79MKII
- Love Them Kaws!
03 Aug 2008 09:21
The offset I bought from eBay is a Kosman, for a KZ or GS. It is a 1/2" offset, 520 chain and I used some spacers behind it too (purchased from Z1 enterprises). The only complaint I have is I was only able to get a 14 tooth front sprocket which meant I had to go small of the rear sprocket too and I like the looks of a bigger sprocket.
I was able to contact the seller today and he thinks he can get one or 2 more in the 14 tooth (I paid $69 for mine). He also said he can have anything made for about $140. I contacted paul gast before I found that one and he will custom make them for about $200.
If you want the email of the gentleman that I bought mine from, shoot me a PM and I'll reply that way. He has a store on eBay but doesn't currently have any 520 offset sprockets listed.
The Kaw List:
- Old Man Rock
03 Aug 2008 17:00
Kosman... should have known...
I had some screwy dealings with them as well. I asked for an 18 tooth 530 with 1/2 inch offset, was sent a 15 tooth. Then they gave me a hard time in returning it...
Damn thing barely made it over the swing arm pivot tube. Only left about 3/16" space, no freaking way was this going to work with out beating the living crap out of my swing arm.
Which swing arm are you using?
Going smaller on the rear, isn't this going to decrease your pivot tube spacing to chain even further?
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
03 Aug 2008 17:51 - 03 Aug 2008 17:52
The swingarm is from Klasmo in Germany and yes, the small sprockets keep the chain real close to the pivot. I had to go small on the rear to get the drive ratio that I wanted. I can't find my receipts, but it looks like I actually have a 15 tooth front, not a 14 like I was thinking. Still, I'd prefer a 16 or 17 since it's a 520 pitch.
Here's a picture of what I ended up with. The clearance looks smaller than it actually is:
The Kaw List:
Last edit: 03 Aug 2008 17:52 by 79MKII.
- 79MKII
- Love Them Kaws!
03 Aug 2008 18:05
The chainguard would look a lot better with a bigger back sprocket too. I'm tempted to have a custom front sprocket made but then I need to buy a new rear sprocket and chain too. That hurts! :pinch:
The Kaw List:
- Old Man Rock
03 Aug 2008 19:03
Question for all...
Going from 630 to 530 the conversion is 630 tooth/5 x 6 for new 530 number of tooth dimensions to calculate out gearing.
Anyone know what the formula is for 630 to 520 conversions?
Should equate to even larger number of teeth I believe.
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
03 Aug 2008 19:09 - 06 Aug 2008 13:26
520, 525 and 530 all have the same 5/8" pitch, so the conversions are the same for all. It's mainly the pin width that's different. The 630 chains have a 3/4" pitch.
OMR - I just re-read your post and realized that I didn't really answer your question. I had a conversion somewhere, so I'll post it if I can find it. Or, if you have the 630 to 530 conversion, it will be the same for the 520.
The Kaw List:
Last edit: 06 Aug 2008 13:26 by 79MKII.
04 Aug 2008 08:09
79mkII,your bike looks like it came together very nicely.do you have complete pictures posted yet?
i have about 700 miles on my custom swingarm,r1 6" rim, 200mm tire,3/8's custom fabbed offset countershaft sprocket with 520 non o-ring rk chain on my 1980 z1r and couldn't be happier.i won't hesitate to put 520 chain on my other z1r and my three other 900's when the time comes. fwiw
- 79MKII
- Love Them Kaws!
04 Aug 2008 09:33 - 04 Aug 2008 09:43
531blackbanshee wrote:
Glad to hear your 520 is doing well. I was very glad to find this thread. I did it because I had to and it has really bothered me ever since. I'm beginning to feel much better about the 520 now.
I'm still waiting for my bodywork to get back from paint. I was able to put another tank on it and take it for a very short ride. Here's what it looks like with an A2 tank and no bodywork. Front fender is temporary:
The Kaw List:
Last edit: 04 Aug 2008 09:43 by 79MKII.
- 79MKII
- Love Them Kaws!
04 Aug 2008 09:42 - 04 Aug 2008 09:42
please delete this post - sorry!
The Kaw List:
Last edit: 04 Aug 2008 09:42 by 79MKII.
