Fork seal replacement problem
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Jun 2008 07:16 - 04 Dec 2008 07:11
#223026
del
Last edit: 04 Dec 2008 07:11 by JMKZHI.
  • RonKZ650
  • RonKZ650's Avatar
Re: Fork seal replacement problem
30 Jun 2008 09:58 - 30 Jun 2008 09:59
#223063
Actually drilling these is extremely easy. I was hesitant, got the drill out and in 30 seconds had the bolt drilled out with no damage.
Last edit: 30 Jun 2008 09:59 by RonKZ650.
  • jrjstuff
  • jrjstuff's Avatar Topic Author
30 Jun 2008 15:03
#223122
JMK is that left hand tread bolt something that is easy to find?
Jeff
83 KZ750 ltd
  • JMKZHI
  • JMKZHI's Avatar
Re: .
30 Jun 2008 17:51 - 04 Dec 2008 07:10
#223153
del
Last edit: 04 Dec 2008 07:10 by JMKZHI.
  • RonKZ650
  • RonKZ650's Avatar
30 Jun 2008 19:58 - 30 Jun 2008 20:08
#223192
The nice part about it is you already have a nice place to start your bit, right in the center of the allen head. Use a bit larger that what the threads of the bolt is. Once you drill it, the head of the allen snaps right off when the drill goes deep enough, then the forks come apart and you can remove the remnant bolt with your fingers as there will be several threads right there waiting for you. It's not frozen or corroded in there most likely because it's bathed in oil. Dirty oil, but oil none the less.
Last edit: 30 Jun 2008 20:08 by RonKZ650.
