usd gsxr forks hit my tank
- jcleach
27 Jun 2008 23:30
I have searched previouse threads and have come up empty handed. I have 05 gsxr600 forks on a 74 z1 with custom stem and I have almost no turning radius. anyone else dealt with this before. do I cut the tank and weld in a half round, beat it in?
- StreetfighterKz
Re: usd gsxr forks hit my tank
28 Jun 2008 03:44
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Old Man Rock
29 Jun 2008 06:23 - 29 Jun 2008 06:25
Just went through this myself...
KZ900-A4 with ZX6R (636) front end. Damn these forks are wide (10")...
1) I had new under tank round dampers so what I did was cut one of the older ones in half (~1/2" in width).
2) With a dremel with a round sand paper disk, curve the surface that will be hitting the new round damper for a good fit.
3) Place your tank into position as normal and you should be ~ 1/2" back. Rotate your forks for clearance from your tank. With some sort of spacer ~ 1/8" in thickness (I used rubber pad) file down the lower tree swing arm stops for desired rotation just pre hitting the rubber pad you have held up on the tank. Give your self at least 1/8".
4) Once satisfied with rotation, then glue the rubber "C" spacers into the under tank "C" clips and let dry.
I use E6000 glue. holds well and is removable if required... This stuff is incredible.
This bought me about another 10-15 degrees of rotation.
NOTE: You will most likely (pending your seat) now be required to shift your seat and possibly tail section back 1/2" as well.... I know pain in the ass but we do need to be able to turn our bikes! Modifications, Ain't it fun!:blink:
Hope this helps,
Old Man Rock
Hope this helps,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 29 Jun 2008 06:25 by Old Man Rock.
- rstnick
29 Jun 2008 10:22
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
29 Jun 2008 10:23
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
29 Jun 2008 10:23
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
30 Jun 2008 07:48
Here's how they did it:
"Well, we marked the location of the indents by just turning the forks from side to side and marking with a pencil. We found a steel tube a little bigger in diameter than the upper fork tubes and cut 2 half sections out of the tube. Then we cut the tank for the steel tubes to fit in. The 1/2 sections were then trimmed to fit and welded in place. Thats where the fun began!
We found that the forks still contacted the tank at the bottom seam. We pounded on the seam to get it as flat as we could, which helped some. We decided not to try messing with the seam of the tank. You could gain a little more room if you cut that area out and welded it back together.
Then it was a little bondo and sanding... lots of sanding!
The other mistake we made was not taking into account the headlight brackets on the fork tubes! They were mounted after and contact the tank sooner than the rest of the fork. We ended up mounting new fork stops on the bottom triple clamp by drilling and taping bolts with aluminum sleeves over them. They contact the stock fork stops on the fork stem tube.
In the end, the lock to lock steering radius is quite poor! The mod looks cool, but practically it's not very functional. You need a lot of room to turn the bike around! It's about a 10 point turn to turn the bike around in my single car driveway! Riding the bike on the street there are no issues, just moving it around in tight spaces! :'(
I hope that helps! Good luck!
Drew
"Drew
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- BlackZ1R
- Kawasaki in my blood
13 Jul 2008 14:23
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- Bad Kaw
- Flying Squirell
17 Jul 2008 22:02
rstnick wrote:
Ewwwwwwww, doesn't this thing rate a 'schwing factor' of 9!!! May have to go to Canada just to see this thing. Yum.
-KR
-KR
78 Kawasaki Z1R
81 Kawasaki KZ1000J (mods)
70 Kawasaki KV75
83 Honda CB1100F (few mods)
70 Kawasaki KV75
- KZ650ftw
17 Jul 2008 22:15 - 17 Jul 2008 22:16
I hate to be the complete newb here, but exactly what year/model is that? It's a beautiful inspiration of what I want my 650 to look like only I think that's a longer tail piece, isn't it? Or is it just due to the rear angle that I'm not totally familiar with yet? Lastly, any profile shots of that beautiful bike?
Bikes: CX500 Custom
Soon to be 79\\\\\\\' KZ650!!!
Bikes: CX500 Custom
Last edit: 17 Jul 2008 22:16 by KZ650ftw.
- Bad Kaw
- Flying Squirell
28 Nov 2008 09:15
Any recent developments?
-KR
-KR
78 Kawasaki Z1R
70 Kawasaki KV75
70 Kawasaki KV75
- barney
28 Nov 2008 14:38
Hey rstnick although I hate to sidetrack the subject. Ive got to see more pics of that bike. Like it aalot
