NEW TIRES!!!! GOT A QUESTION
- mtkawboy
Re: NEW TIRES!!!! GOT A QUESTION
27 Jun 2008 09:03
The age of the old tires will determine how hard it will be to change them. Getting them off can be a bear if they are ancient & hard. Get the tire irons and give it a try or youll never know. If it has spoke wheels watch the rim locks pinching the tubes. If it has cast wheels make or buy some rim guards so you dont booger them all up
- wiredgeorge
27 Jun 2008 11:44
Changing a tire can be frustrating. Everybody knows someone who does it with a couple screwdrivers but if you try and change a 15" or 16" touring bike tire, even using a tire machine can be frustrating. A 19" rim is much easier for some reason. I would rather pay somebody else to do it even though I can just because it is such a pain. The biggest advantage with a tire machine (mine is manual) is that you have a 3' tire iron that gives you leverage and a decent way of holding the tire in place while you grunt. I have found that soapy water tends to rust the inside of chromed rims... not sure that the tire lubricant is much better but I use that stuff. And in case the do-it-yourselfer doesn't know this, you can't seat the bead of a tire using a bicycle air pump. A good sized compressor is needed and some know-how here as well. They make blow up contraptions that go around the installed tire and you blow them up; they shove the bead outwards towards the rim and these things do work decently but some tires are just TOUGH... Others seat easily. Dunno why. My advice is to take it to a shop. Don't watch the guy who does the work because if it goes easy, you were robbed... unless you have done it yourself and know what a PAIN it can be.
- steell
27 Jun 2008 12:10
The larger the rim diameter the easier it is to remove and install the tire. 6"-8" garden tractor tires are a real pain, 24" big truck tires are a breeze, motorcycle tires fall somewhere in between.
Use tire irons, they're cheap and will last several lifetimes (your great-great grandkids can use them), don't even think about using screwdrivers unless you want to ding your rims.
Use a large C-clamp to break the bead on tubeless tires, unless you have a tire changer.
Seating the bead on new tubeless tires is "usually" pretty easy, used tires will give you fits sometimes.
I've changed everything from garden tractor tires to the huge earthmover tires, so motorcycle tires are a breeze (and I have tire irons and a tire changer, but on motorcycle tires I just use the tire changer to break the bead).
- bountyhunter
27 Jun 2008 12:10
JMKZHI wrote:
Here's a trick on rears: the rim strips (to protect the tube from the ends of the spokes) are a royal pain if you are trying to make them go OVER the rim lock blocks. I used to cut a hole in the rim strip for it's bolt and let the rim lock lay on top of it. The rim lock is rubber so it doesn't hurt to let the tube run across it. That makes it a little easier to manipulate the rim locks.
Then I tried the rear. I got half the tire on & one rim stopper in, but that's as far as I could take it. So CycleGear finished the job.
- JMKZHI
Last edit: 04 Dec 2008 06:55 by JMKZHI.
- bountyhunter
27 Jun 2008 17:12
JMKZHI wrote:
This is wisdom....
Nope. The problem was the tire - the bead on the GT501 is hard & was killing my hands as I tried to manuever the rim stoppers & tube in there. I installed the rim strip first after using a hole puncher to make some holes for the stopper stems.
This is wisdom....
- jp_goody
27 Jun 2008 18:25
WOW, tire changing is a passionate subject. Im preparing myself and vow not to get really pissed off!! haha.
Im a converted car nut so ive got the compressor. Will check the local shop for some tire irons.
Oh, one more question. The bike is a shaft drive...will I loose fluid when removing the rear wheel????
Again, thanks a ton for the insight guys.
- JMKZHI
Last edit: 04 Dec 2008 06:57 by JMKZHI.
- wiredgeorge
27 Jun 2008 20:45
No fluids will come out when removing the rear tire. You need to get the rear tire up off the ground. Centerstand won't do it. You need a lift or if you use the centerstand, you could tie the front tire down good. Anyway, remove the axle nut, make sure you pay attention to washers/spacers and tap out the axle. Once you get the axle out, if sitting behind the tire, pull it to the right to free it from the fingers in the final drive. There is no oil in the final drive where it connects to the rim... only grease.
- jp_goody
27 Jun 2008 21:39
Ahhhhh F-it!!!!!!! Sorry guys, i gave a noble effort.
It was quite the sceen had youd seen it. Its thundering and lighting like hell her in KC MO tonight. Flashing in the windows, HIST channel on the TV, (yes, all garages should have cable for the HIST channel) And Im sweatin my A$$ off with SEVERAL different screw drivers, pokers, and a odd curved hook thingys I found tonight at the store. (Nope, couldnt find a tire iron!!) All was a wash.
The current tires are not worn, just dry-rotted as hell and VERY VERY VERY hard. Plus I had no idea how deep/long the dang lip was gonna be.
TO EVERYONE WHO HAS SUCEEDED....YOU ARE TRUE MEN MY FRIENDS! The only thing i have to be proud of was my setup I had workin for me....pic below. TTYL guys.-jason
[img] [img]http://i302.photobucket.com/albums/nn112/jp_goody/06-27-08_2229.jpg[/img] [img]
- jp_goody
- steell
28 Jun 2008 03:28
My Nephew (GPzInfested) and I are going to install GT501's on his 750 Turbo today, maybe I should take and post some pics?
I'll probably let him do all the work while I supervise
