Pulling the swing arm Questions.
  • ran429
  • ran429's Avatar Topic Author
  • Master of FREE rides!
07 Feb 2006 11:49
#22184
When I pull off the swing arm. What should I do.
Replace all the Bushings or Just Grease them after inspecting for wear?
Should I drill a Hole in the tube for a Zirc fitting so I can grease it periodically? I dont see one on it currently.
I am going to Just sand down all the current paint and then Prime it again then Shoot some Black back on it, I am going to paint the Whole bike black and the only chrome will be on the forks and possibly shifters and Levers. Anything else that is shiny will be blasted and Blacked out if possible.
  • wireman
  • wireman's Avatar
  • Visitor
Re: Pulling the swing arm Questions.
07 Feb 2006 11:54
#22186
if it has the double needle bearings and they are still good id just put a grease zerk in it and ride like the wind!B) hows your back situation coming along?goodluck,happy wrenching!
  • ran429
07 Feb 2006 11:57
#22187
im ignoring my back as much as possible (until it really hurts)
I want my bike back on the road asap, so I have been tinkering a little bit here and there when I can manage to get out there.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
07 Feb 2006 12:04
#22192
I happen to be doing this right now, too.
I have to believe that if there's no grease thingy, there cannot be needle bearings. Can anyone say "grind"? ;) My bearings were worn, rusty, and partially frozen (the outside two, anyway) even *with* a grease thingy. and they were not easy to get out....
I hope you have bushings, and I hope thye are not worn. If I were you, I'd replace them anyway. I mean, how often will you have the swingarm off for paint/maintenance?
(1.) '75/'76 KZ400D - Commuter
(4.) '75 KZ400D - Sold
kz750twins.com
  • rattler
  • rattler's Avatar
08 Feb 2006 12:27
#22506
i would just go ahead and replace them while i had the swingarm off. i picked up some from my local wheel and bearing shop for nine dollars. i had a fitting put in my stock swingarm a couple of years back so i could gears them twice a year.
Post edited by: rattler, at: 2006/02/08 15:28
