630 to 530 Chain Conversion
- otakar
Re: 630 to 530 Chain Conversion
21 Aug 2011 12:12 - 21 Aug 2011 12:31
Just talk to Z1E and they will set you up. They have all the required sprockets and chains for the 530 conversion. They have both the Z-12 and Z-13 spline front sprockets for the older bikes and "J" series bikes. The Tsubaki "Sigma" chain they got for me is also fantastic. I only have to tighten it very seldom. some brand sprockets WILL require a spacer washer and they have those also. They have 1.25 & 6mm washer thicknesses. On my"J" motor I used no spacer. I cover my conversion here. on pages 23-27
kzrider.com/forum/11-projects/169462-bui...0?limit=20&start=460
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Aug 2011 12:31 by otakar.
- riverroad
- 1980 1000LTD B4
- otakar
21 Aug 2011 12:37
I sent you one back.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- gfmarsh
21 Aug 2011 13:56
I was looking at the Z1 site. It says the sprockets will be the same diameter but with more teeth. The ones I received from Thibeault were quite a bit smaller but had the same number of teeth as I recall. I guess it would translate out to be the same as the original as far as rotational speed vs. engine speed. Thanks for the info.
1981 Kawasaki KZ1000 J, bought in 1991
2004 ZZR1200, bought in 2005
Have also owned a 1981 KZ550 (first bike), 1984 Ninja 900, 1978 RD400, and a 1982 BMW R65
- trianglelaguna
21 Aug 2011 14:06
one of the things anyone over 30 loves to point to and talk about,my 630 chain,all cleaned up and shiny...just the right clear coat of modern repsol lube, just the right slack,,big old steel rear sprocket ,new teeth no dirt...it fits there,belongs there,big rim,big old bike,big old chain....they love it...
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- trianglelaguna
21 Aug 2011 14:07
it's worth the buck fiffy
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- gfmarsh
22 Aug 2011 01:33
You may have a point there trianglelaguna.
- Jeff.Saunders
22 Aug 2011 08:02
gf - If you are running very small sprockets front and back on the bike, you are likely to have the chain slap the top or bottom of the swing arm...
- otakar
22 Aug 2011 08:32
95% of people would not be able to tell the difference between a 530 and 630 by sight. I am WAY over 30 and could not tell the difference at a glance. The chains LOOK almost identical.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
22 Aug 2011 09:23otakar wrote: 95% of people would not be able to tell the difference between a 530 and 630 by sight. I am WAY over 30 and could not tell the difference at a glance. The chains LOOK almost identical.
Folks who are ashamed of their little 530's and secretly envious of those with 630's, might find it somewhat consoling to fab a full chain cover so nobody can see the chain, and could even paste a label on the cover that says "630."
Another label could be added that says, "If under 30, do not look under this cover."
:laugh: :laugh: :laugh: :laugh:
The following user(s) said Thank You: 82KZ305Belt
- otakar
22 Aug 2011 13:10
Only the ones insecure with their masculinity. It's not the size of the chain but how much Horse power you have behind it. some guys just think that it's all just in the Chain.
:laugh: :laugh: :laugh: :laugh: :whistle: :evil:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
22 Aug 2011 13:52
everytime i see a post where someone is sweating going to a smaller chain.
i smile,
and keep piling the miles on my 190 mm wide rear tire and 520 chain. :evil: :whistle:
run what makes you happy.
they are all fine for what we do.
i smile,
