Wobbling front end around turns
  • jbrewer73
  • jbrewer73's Avatar Topic Author
19 Jun 2008 12:21
#220935
I have a 77’ KZ1000 with good tires on it. I owned it for about a year and has always wobbled a little around turns. It kind of hops or jumps.
It is fine going straight.
Any ideas????
THX
  • mariozappa
  • mariozappa's Avatar
Re: Wobbling front end around turns
19 Jun 2008 12:29
#220939
Steering stem nut too loose?
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
  • BSKZ650
  • BSKZ650's Avatar
19 Jun 2008 15:04
#220959
also look at the wheel bearings, loose or bad
77 ltd1000, current rider
76 kz900, just waiting
  • kneedragger80
  • kneedragger80's Avatar
19 Jun 2008 16:14
#220975
My 750 wobbled like crazy in the corners . .. until I tightened up the front axle clamp bolts.
80 KZ750E
84 GPZ1100
NY US
. . . I used to do a little but a little wouldn t do it so a little got more and more . . .
  • Z1R rider
  • Z1R rider's Avatar
19 Jun 2008 17:18 - 19 Jun 2008 17:19
#220986
Or maybe too tight, or races dented. (these usually make it wander around going straight also) Have you checked the rim runout? How fast are we talking in the corners? Just a normal speed or crankin' her over, dragin' the pegs? Rear end springs too stiff, or shocks shot or swingarm bearings bad? Could take a while to find, but keep checking things and you'll find the problem. :)
1978 KZ1000, Z1R
1999 250 Ninja race bike
Last edit: 19 Jun 2008 17:19 by Z1R rider.
  • KZQ
  • KZQ's Avatar
  • Online
  • Administrator
  • Administrator
19 Jun 2008 19:06
#221013
Check your swing arm bushings/bearings. They'll have a similar effect if worn.
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
19 Jun 2008 20:28
#221028
Proper wheel-alignment,and if you do ANYTHING with the steering bearings...swap them to tapered!Big difference in how the bike will handle.I have the same bike as you,and I could not believe the difference it made.
And yes,like mentioned...swingarm bushings.
Have you ever had any work done on the forks?Maybe it's time to put new seals and oil in them...could be getting spongy on ya.
1977 KZ1000 A-1
