Any difference in police cast wheels and early LTD cast wheels?
- Duck
- e vica na i sau na ga
07 Feb 2006 05:36
Maybe a better question is...
What variations are there among the stock cast wheels?
Also curious if a nice set of cast wheels would have any value in swap toward a nice set of wires.
Thanks.
-Duck
Thanks.
-Duck
- JMKZHI
Last edit: 03 Dec 2008 20:04 by JMKZHI.
- rstnick
Re: Any difference in police cast wheels and early LTD cast wheels?
07 Feb 2006 17:43
I have a set of mags from a '79 650 C3. 19" front and 18" rear. Dual disc up front and single disc in back. The discs have been sold as well as the front calipers and master cylinder are gone. The rear swing arm I still have as well as the rear master cylinder and caliper, which both would need rebuilding.
Post edited by: rstnick, at: 2006/02/07 20:44
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- RV
31 Mar 2007 09:50
howzit brah!
police front wheels are 18"s, are wider at the disc-mount flanges- the whole front assy is wider.
don't know about LTD's, but I think they use a 4-bolt disc mount pattern(you mentioned "early"); the "P's" have a 6-bolt pattern.
- Duck
31 Mar 2007 12:26
Learned a little since original post
But, police fronts are 18"? Are you sure?
Police rear is 18". Old LTD rear is 16".
-Duck
-Duck
- Pterosaur
31 Mar 2007 12:30
Duck wrote:
On the "C" models I am - 18"s front & rear.
-Duck
- z1rick
31 Mar 2007 15:00
Just checked my '99 1000P, 18" frnt. and Rear.
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
1999 KZ 100P
1974 Z1 900 Project
- Mark Wing
31 Mar 2007 16:33
Here's what I know. All KZ's and LTD's have a 19 front, KZ's have a 18 rear and LTD's have a 16 rear, Z1R's have 18's front and rear as well as police having 18's on both ends. The police and the LTD's have the shinny area on the flat of the rim between the spokes and rhe rim face.
Real early KZ's just have a smooth edge, no rim lip. 19x1.85 18x2.15
Later KZ's with lip 19x1.85 18x2.15
Z1R front 18 rim lip 18x1.85
LTD rear 16x3.00
Police Front 18x2.15 rear 18x2.50
LTD rear 16x3.00
Yorba Linda Cal.
Yorba Linda Cal.
- RV
31 Mar 2007 17:15
so sorry duck, I mentioned in ERROR police discs had a 6 hole bolt pattern- it's 7. sorry, wires crossed with other projects....RV
- Duck
01 Apr 2007 17:07
RV wrote:
No problem.
I dug the KZP roller out from behind the pile of 'what was I thinking?' bikes this afternoon. Yep. 18" front and rear.
Took half the day to get to it
A KZ frame is more practical than the police when it comes to a home for my KZ engine. If any of you local guys care to swap, let me know. Otherwise I'm gonna start cutting and welding come June(after the Triumph twins are done). I have impound lot auction paperwork with the police frame.
-Duck
No problem.
-Duck
- The Gringo
- ¡Usted no necesita otra motocicleta!
02 Apr 2007 05:35
JMKZHI wrote:
I did a mag swap on my 81 650CSR and used mags from a 550 LTD. It is a 100% bolt on swap nothing to modify at all. If you are looking to replace your spokes you might want to try using these as the 550 LTD's are more plentiful than the 650 F's. You should be able to find lots of 550 mags on Ebay and they usually don't fetch more than 25 or 30 bucks. Also the 650 F used an 18" rear wheel so you would have to buy a rear tire as well.
I'd like to trade the wire wheels on my 81 KZ650-CSR for a set of cast wheels from an 80 KZ650-F - reference nickap's bike. To me it's a pain to clean & de-rustify all those spokes. And with the wire spoke wheels there's also the additional spoke tightening maintenance. I'm a little lazy about some tasks....Also curious if a nice set of cast wheels would have any value in swap toward a nice set of wires...
JMK.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
