no pressure in front fork shocks
  • killcity
  • killcity's Avatar Topic Author
16 Jun 2008 15:23
#220375
hey everyone, the air pressure in the front shocks seems to be leaking, what should i check? im not familiar with this style of shock :/
thanks!
bj / '80 750ltd
  • JMKZHI
  • JMKZHI's Avatar
Re: .
16 Jun 2008 15:49 - 04 Dec 2008 06:40
#220384
del
Last edit: 04 Dec 2008 06:40 by JMKZHI.
  • Saki Jockey
  • Saki Jockey's Avatar
Re: no pressure in front fork shocks
16 Jun 2008 18:42
#220410
It's almost guaranteed they're leaking at the fork seals (beneath the wiper seals exposed on fork). Pressurize the forks (Never exceed 20 psi as will blow out the seals for sure) and spray a soap and water solution around the wiper seals.
Rob.
Rob A.
550 A4
GTA,
Ontario, Canada
  • killcity
20 Jun 2008 09:08
#221115
thanks everyone! ill try the soap test and see what happens. if they seem to be leaking, how big of a pain is replacing the seals?
  • OKC_Kent
  • OKC_Kent's Avatar
20 Jun 2008 09:33
#221119
There are quite a few threads here addressing the seal replacement, and a writeup in the Filebase section of KZRider.
DO NOT use a compressor or anything bigger than a small hand pump to pressurize the forks or shocks on a bike.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • jon0108
  • jon0108's Avatar
06 Aug 2008 18:31
#230577
found my leak to be the schrader valve itself.
