How to Remove Handlebar Grip
- TLH101
06 Feb 2006 19:59
OK, I broke my clutch perch, and need to remove the grip to slide the new one on. Can this be done without destroying the grip, and if not, what is the best way to retain the new grip?
Don't even ask me how I broke the perch, while installing a new mirror, that seemed a "liitle" tight. Did you know the mirror hole on the top of the perch is not blind?:blush:
- incognito0160
Re: How to Remove Handlebar Grip
06 Feb 2006 20:09
From my experience you will not be able to save the grip. I cut mine of with a utility knife and bout new one. I then used hair spray. Applied it to the handle bar and slide my grip on. I believe that's what the instructions said as well.
- ten6
06 Feb 2006 20:13
I have had good luck using a wide blade flat screwdriver to gently pry up the edge of the grip. I then spray WD-40 or PB Blaster under the grip. Alternate working the screwdriver and spraying the grip. Sometimes a small bit of heat applied to the bars helps the stubborn ones. I have NEVER lost a grip yet...this does work.
Michigan City, Indiana
Firefighter MCFD IAFF Local #475
(3) KZ650s (1) 1996 Vulcan 1500A (1) 1978 KZ1000 (1) 1986 Yamaha Radian 600
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
2000 Dodge Ram 4x4
1960 Chevy Bel-Air
- RomSpaceKnight
06 Feb 2006 20:18
I've had some luck using compressed air. A small nozzle slipped under the edge might lift the grip enough to slide off. Use dish soap as a lube as it will eventually wash away.
- CHARLESRAD
06 Feb 2006 20:24
use an air compressor thats how I change my grips nothing else but the air. They will slide right off, mine were not glued on though.
- 77KZ650
06 Feb 2006 23:01
If you're going to try heat, use a hairdryer, that way you won't burn/melt anything, good luck
07 MDP Rookie of the Year
- FireBurst
- TLH101
07 Feb 2006 05:54
Oooh, optimism abounds. May I can save it. Thanks for all the tips.
- tfh903
07 Feb 2006 16:38
I use a long thin screwdriver and either slick soapy water or wd40. gently pry up and then work the screwdriver all the way around adding slippery stuff , then twist and pull.
- MaddMaxx
12 Feb 2006 00:18
I just did one last night and the same method always works for me, crank the compressor up, lodge the nozzle under the grip and pull the handle. As the air enters the area around the grip pull and twist. No need for lubes or anything else until you go to put it back on.
- wireman
12 Feb 2006 12:19
just took a set off with the good ol utility knife,they were glued on!:whistle:
