ZX636 Front End on KZ900: Need Front Turn Angles from Someone...
- Old Man Rock
12 Jun 2008 19:03
Hey all,
In installing my Zx636 front end on my KZ900, it seems like the turn angles are really short due to triple tree stops. The KZ forks are 8" wide while the ZX are 10", will have to make some slight mods to the tank (move backwards 1/2" or so.
For those of you that have completed a ZX636 front end swap, can someone do so simple measurements for feedback.
I would think the following would be sufficient but if anyone has a better way please by all means feel free to help out.
With the wheel straight, place a piece of tape on the concrete and mark dead center. Rotate left, tape & mark and repeat for the right. What measurements do you guys come up with off dead center?
Thanks,
Old Man Rock
Thanks,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Z1109R Fin
Re: ZX636 Front End on KZ900: Need Front Turn Angles from Someone...
13 Jun 2008 03:09
Before making any mods to the new front put the tank on and carefully try turning left and right. Eventhough trees are wider they can be less off-set and much thicker forks which means that turning radius will be much bigger than with stock front. I just swithed from a ZX7R front to a GSXR -98 USD -front (bike originally ´83 ELR) and turning radius i now even worse i.e turns less than before.
Z1000R ´83...Slightly modified...
- StreetfighterKz
13 Jun 2008 04:34 - 13 Jun 2008 04:35
I don't know what seat you have but the Corbin normally leaves a gap between it and that tank and I moved my front tank mounts back to gain some steering angle with the '01 Gsxr forks I have. I cut the stock mounts off and welded them back on to a notch that was already made on the coil mounts. I was able to move the tank back about a 1/2 inch or so this way.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 13 Jun 2008 04:35 by StreetfighterKz.
- Old Man Rock
13 Jun 2008 12:10
"I cut the stock mounts off and welded them back on to a notch that was already made on the coil mounts. I was able to move the tank back about a 1/2 inch or so this way."
Yep, same here. Actually, all I did was epoxy some 1/2" objects in the underside tank "C" so the rubber doesn't go all the way into them. Then with a little pressure, squeezed the "C" around the rubber mounts. Nice tight fit.
In doing so, I have been able to increase my angles significantly but still not sure how much I should be seeing. I should just go to the bike shop and confirm through rotating a new bike front end...
I too have a Corbin seat "Gun Fighter" and will have to modify the under seat mounts and latch 1/2" back as well... DOH!
Thanks guys,
OMR
Thanks guys,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
