Shortest stock KZ clutch cable?
  • Robinjo
  • Robinjo's Avatar Topic Author
11 Jun 2008 17:58
#219443
I'm in need for a new clutch cable for my Z1 powered Moto Martin, currently the bike has some normal touring bars on it but the bike is meant to have clip-ons to compliment the race fairing, this leaves me with lots of unneeded cable lenght if I order a stock Z1 cable.
I'm new to old Kawa's but there must be models which have sportier handlebars (Z1R?) and taller ones (LTD)?
Or can you get different lenghts aftermarket?
Moto Martin Z900 1981/73 engine
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Shortest stock KZ clutch cable?
11 Jun 2008 18:09
#219449
A cable from a Z1R is going to be about the shortest you can find from the OEM that I know of. I did find a couple Motion Pro or Barnett (can't remember which) that were either 2" or 4" shorter than a normal Kz. Shorter aftermarket cable are out there but hard to find. Most people just go with a Z1R cable.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • Vter Bob
  • Vter Bob's Avatar
11 Jun 2008 18:12
#219450
Try contacting Z1 Enterprises. They sell Motion Pro cables and I'm pretty sure Motion Pro is willing to make custom length cables.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • Robinjo
12 Jun 2008 17:22
#219687
Thanks guys, I will get in touch with Z1enterprises, I already have very positive experiences with them buying Suzuki parts. :huh: ;)
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
13 Jun 2008 15:56
#219865
www.z1enterprises.com/detail.aspx?ID=283
That is the shortest readily available cable. The Z1R has bars with only a 2"-2.5" or so rise (50mm-65mm).
Motion Pro makes any length you need. We have worked with Motion Pro to make a number of custom cables - some just shorter /longer versions of stock cables, others having different ends where alternate carbs or throttle assemblies are fitted.
  • Robinjo
14 Jun 2008 15:51
#220016
Or wait a little 'till Jeff posts in my topic. :)
I've tried the clip-on bars seating position but didn't like them, fitted a set of aluminum Superbike bars instead.B) Will order a cable along with some other stuff as I make a list.
Thanks guys for the info!
Robin
  • dnyce
  • dnyce's Avatar
14 Jun 2008 16:35
#220024
is there a price difference for custom cables? i went with clip-ons and they're perfect for me. maybe i should just email you
  • Jeff.Saunders
  • Vendor
  • Vendor
15 Jun 2008 08:31
#220152
Custom cables - depending on what is needed, they range from around $25 up to $50 each.
