Question about fork seal backup washer
- brokenrod
11 Jun 2008 06:52
Hi all,
I am in the midst of replacing the fork seals on my '81 GPZ1100 and have come to a screeching halt because i dont know which set of directions i should follow. in the mother Kaw repair manual, it shows that the backup washer goes under the fork seal. In the direction booklet i have from the Leak Proof seals it says and shows the washer sitting on top of the seal (between the seal and circlip). personally i think it makes more sense to place it on top of the seal but i wanted some opinions as i really dont want to do this multiple times. - BTW, when i disassembled the forks, the washer was originally under the seal. thanks for the help as always.
I started out with nothing, and still have most of it...
1981 GPZ1100, 1981 kz1000m1(csr), 1979 suzuki gs425
- RonKZ650
Re: Question about fork seal backup washer
11 Jun 2008 07:50
Kawasaki parts diagram shows the washer goes under the seal. That does seem rather odd, but seems to be correct.
- 893cv
11 Jun 2008 08:26
The washer does go under the seal. I have never had any long term luck with the "Leak Proof" seals. They always seem to leak in no time. I always try to use OEM seals.
1980 kz1000 LTD
1978 Z1R
1978 Z1R
- RonKZ650
11 Jun 2008 09:56
I put leak proof seals in my 82 GPZ1100 and they were not in fact "leak proof". Mine leaked within a couple days. Factory seal are definately the way to go.
- brokenrod
11 Jun 2008 15:05
thanks for the good news i guess:unsure: . looks like i should have gotten the oem replacements. i will try it anyway since i need to get to work somehow. looks like i'll probably be doing it multiple times anyway:angry:
