Rear shocks (I know there is another thread like this, I didn't want to hijack it)
- Becker
- The Doctor Will Rise Again
10 Jun 2008 12:56
Someone else has a thread about what rear shocks to buy and I have been looking for a new set for awhile now. My problem is I weigh 275 pounds and the stock shocks are old and tired. I don't normally ride with a passenger but with these shocks on I almost can't because it makes the front wheel hunt around when I do. So how many pounds of pressure should I be looking for in a set of shocks?? When they say the pressure designation on the spring is that how much weight (rider and gear) they can handle??
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
- bountyhunter
Re: Rear shocks (I know there is another thread like this, I didn't want to hijack it)
10 Jun 2008 21:49 - 10 Jun 2008 21:52
Becker wrote:
But, your body's center of mass is not directly above the shock, it's a little forward so the "load rating" the shock can handle is higher than the spring ratings.
The 80/125 is what I run and it's perfect for me (I weight 170 lbs).
If I recall, the highest maximum spring ratings are in the 160 - 180 range and that would probably be the ballpark for your body weight. If you take a passenger, you probably need the strongest springs available (the passenger is right above the rear shocks and loads them squarely on). Somebody may have a chart to convert spring weights to body weight but I haven't seen one.
Definitely not. The pressure rating on the spring (like 80/125) is the pound force it takes to deflect it one inch (first rating) and two inches (second rating) AT THE SHOCK ABSORBER.Someone else has a thread about what rear shocks to buy and I have been looking for a new set for awhile now. My problem is I weigh 275 pounds and the stock shocks are old and tired. I don't normally ride with a passenger but with these shocks on I almost can't because it makes the front wheel hunt around when I do. So how many pounds of pressure should I be looking for in a set of shocks?? When they say the pressure designation on the spring is that how much weight (rider and gear) they can handle??
Last edit: 10 Jun 2008 21:52 by bountyhunter.
- Becker
11 Jun 2008 20:51
Sweet, thats exactly the kind of answer I was looking for. Thanks. Now its time to go shock hunting.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
