Changing gear ratios (rear sprocket) on KZ650
- TLH101
06 Feb 2006 11:11
Has anyone ever used a smaller rear sprocket on a KZ650? Mine is running at nearly 4500 RPM at 70mph. I was thinking that I can change the rear sprocket to get the RPMs down. Anyone have any advice on this idea? I have a '78 KZ650 with a 42t rear sprocket.
- steell
Re: Changing gear ratios (rear sprocket) on KZ650
06 Feb 2006 11:19
The front sprocket is cheaper than the rear, and going up one tooth on front equals approximately 3 teeth on the rear. Buy a front sprocket one tooth larger than your current one and see if you like it better. There will probably be enough adjustment with your chain adjusters to take up the slack, assuming your chain and sprockets are good.
Post edited by: steell, at: 2006/02/06 14:20
- OKC_Kent
06 Feb 2006 12:47
It sounds like your gearing is low to start with, my bike runs 58mph at 4500 rpm. I have stock gearing too. What is your front sprocket now?
Stock is 16 front - 42 rear.
Post edited by: OKC_Kent, at: 2006/02/06 16:04
Cashion, OK
78 KZ650 B2 85,000+ miles
- reborn650
06 Feb 2006 13:50
Steell is right. Better to change the cheaper front one and it is far simpler of a task than swapping out the rear sprocket. You will find that your acceleration off the line will suffer and you might have to bang it down a gear to 4th to pull out to pass on the highway if it is a bone-stock 650.
Cheers-Colin
Cheers-Colin
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
- OnkelB
06 Feb 2006 14:51
Apart from everything being said so far being correct, a 38T rear sprocket for a 750 Twin is a direct bolt-on to the 650 sprocket hub - the center hole is slightly larger, but the bolt holes line up perfectly.
I´ve been running the 38T rear with a stock 16T front on my 650 for a couple of years and have been very happy with it. It will slow acceleration a bit, but I think the benefit on the highway is worth it. Actually think the rear is easier to change too, but maybe that´s just me.
77 KZ 650 B1, 82 GPz 1100 B2.
- sorner
20 Jun 2007 11:36
Thats it? Hell! My 305 is up around 6000RPMs at 60mph!
- RonKZ650
20 Jun 2007 13:17
Yea, I think the 4500rpm @70 is a mistake. Stock gearing is between 5000-5500rpm at 70mph depending on tire sizes and tach/speedo variations.
- ronjones
20 Jun 2007 13:19
TLH101 wrote:
Terry, are you sure you're doing 4500rpm@70? I would think that's pretty good. Look at what the other's have posted w/their bikes. "58mph at 4500 rpm", "6000RPMs at 60mph", I'm doing 5K@70, with my twin, and I thought that was good. I went up to the 17T on the front sprocket and I'm quite pleased as it doesn't seem to have taken anything off the lowend.
Ron
Post edited by: ronjones, at: 2007/06/20 16:20
Ron
- The Milkman
20 Jun 2007 14:16
I think 4500 is low too,,:laugh: :woohoo: . I went up 1 tooth on the front with mine and get 5K @ 70 too and once in a while take off in second from a stop at a stop light with no problem at all. I'm thinking about dropping to a 40 on the rear too but I'm not a performance minded individual either.. :laugh: :laugh:
Ride safe.
Ride safe.
- davenkids2001
21 Jun 2007 06:50
ronjones wrote:
I agree with the above. My SR 650 turns 5300 rpm at 70 mph.
I posted my experience about changing my 16-41 to a 16-40 ratio last spring. I'd be pleased to get 4500 rpm at 70 mph!
Here's the link to my post:
kzrider.com/component/option,com_joomlab...w/catid,5/id,123898/
TLH101 wrote:Has anyone ever used a smaller rear sprocket on a KZ650? Mine is running at nearly 4500 RPM at 70mph. I was thinking that I can change the rear sprocket to get the RPMs down. Anyone have any advice on this idea? I have a '78 KZ650 with a 42t rear sprocket.
Ron<br><br>Post edited by: ronjones, at: 2007/06/20 16:20
Dave and Janet
Great Lake State
1979 650SR
Great Lake State
1979 650SR
- Bluemeanie
22 Jun 2007 06:18
I'm running 16/42 combo and tac out at about 5,800rpm @ 70mph.
- CoreyClough
- GPz550 Addiction
22 Jun 2007 07:54If you have Excel on the top of this picture you can copy the link, and input your gear, tire, and sprocket information, and have fun playing.
www.cunnington1.freeserve.co.uk/gearing_v12.xls
I've previewed it, and posted the link here. This computer I'm using doesn't have Excel, so I can't check to see if it works.
'85 GPz550(ZX550-A2)
