rear shocks (new)
  • pburnhamb
  • pburnhamb's Avatar Topic Author
rear shocks (new)
09 Jun 2008 17:40
#219023
Anyone have a recomendation for new rear shocks? ive got a 78 kz650. ive got my eye in these MDI shocks black and chrome, but not sure if i should go with the 440lb or 255lb or if anyone has another brand i should try. she is slowly turning into a cafe racer so i wanna keep in line with this look.
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
  • mr anderson
  • mr anderson's Avatar
Re: rear shocks (new)
10 Jun 2008 08:19
#219115
Last night I replaced my stock shocks on my 77' 650 with stock shocks from a 2005 suzuki boulevard. it lowerd the bike just shy of 2" and are alot stiffer and shinier than the stock ones.
  • mr anderson
10 Jun 2008 08:20 - 10 Jun 2008 08:21
#219116
Last edit: 10 Jun 2008 08:21 by mr anderson.
  • The Gringo
  • The Gringo's Avatar
  • ¡Usted no necesita otra motocicleta!
10 Jun 2008 08:36
#219122
I've become a big fam of using stock shocks from a Vulcan on my 650's. They are about 1.25" shorter than stock and can be had on ebay at a pretty reasonable price. I now have them on 2 of my 650's and paid $30 for one set and $40 for the other set including shipping. It gives the bike a sort of slammed look and since I only have a 28" inseam it makes it easier to flatfoot the bike. The shocks I've been buying are off a 500 Vulcan but if you want more adjustability you can also use the 750/800 Vulcan shocks which come with the air adjust feature. They usually fetch a few more bucks though. Here is a pic of one of my bikes with the Vulcan shocks installed.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
  • anarki650
  • anarki650's Avatar
10 Jun 2008 08:58
#219125
I recently replaced my stock shocks on my 77 kz650 cafe racer with progressive wound (not Progressive brand though, too much coin for me) that I bought off of www.mikesxs.com . They are available in three lengths for $79 for the pair, or you could go with the piggybacks for $169 a pair if you want to spend some more coin. I have put a couple hundred miles on mine and have nothing but good to say about them, and they were a direct bolt up.
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
  • bountyhunter
  • bountyhunter's Avatar
10 Jun 2008 12:09
#219160
I got the progressive brand coil springs and gas shock sets for my 750. They are not cheap, but they are the best for street riding for combined performance and comfort. Z1 sells them and installs the springs on the shock for free.
  • pburnhamb
10 Jun 2008 14:25
#219178
I cheched out mixesxs.com those are a lot like the ones i saw at www.hvccycle.com/mdischocks.htm so what length did you end up going with? 12 3/4? what does the bike call for, the ones on her now are about 12.5 , but im not sure they are stock. what is stock length? also is these alot stiffer?
thanks for the help.
1976 kz900
1977 xs650
  • anarki650
10 Jun 2008 18:23
#219233
I went with the 12 3/4" which are close to the same length as stock, might be just a hair longer. They are quite a bit stiffer than stock, I had my pre-load set as heavy as possible on the stock shocks I replaced and it was still quite squishy. On the mikesxs replacements I have them in middle position and they are significantly more firm than the stock set on full preload. Very responsive feel to them as well. I really can't say enough about them for the price and the performance.
09 Kawasaki ER6n
Omaha NE
  • pburnhamb
10 Jun 2008 19:19
#219249
these sound like the way to go then. are the black caps metal? theyre not plastic are they?
1976 kz900
1977 xs650
  • anarki650
11 Jun 2008 07:44
#219324
They are metal. And the shocks come with an assortment of ruber grommets, including the correct size to mount them on our bikes. And Mikesxs has free shipping. :woohoo:
09 Kawasaki ER6n
Omaha NE
