Rear brake pedal stud?? bolt??
- patmann
09 Jun 2008 08:03 - 09 Jun 2008 08:04
What I'm trying to ask is.. is it a welded or screw in part?
Now for the description...
This is the part that the pedal itself slides onto.
Somehow ( don't ask ) mine snapped of the head with the threaded part with the washer and acorn nut that keeps the pedal in place. The pedal stays on, but it wants to slide "off" . Not really off, just to the outside of the of the bolt, stud, whatever it is.
I'm soo po'ed I haven't even looked to close yet. I've looked at my exploded views of the frame and such on the microfish cd, but can't tell.
Anyone?? AND how should I fix it?? :dry:
It's on my 1974 Z1 900 of course.. not one of the project bikes that I'll never get abound to fixing.
I thank you in advance, Pat
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Last edit: 09 Jun 2008 08:04 by patmann.
- Sandy
- Fly High,Tony
Re: Rear brake pedal stud?? bolt??
09 Jun 2008 08:32
Well here's a pic of that section,but I can't tell from it,how that pedal IS attached to the frame.
It doesn't show a bolt in the diagram.:blink:
1977 KZ1000 A-1
- StreetfighterKz
09 Jun 2008 08:47 - 09 Jun 2008 08:48
Pretty sure it's welded on. The stud for the pedal is welded on the '76 900 and the '78 1000 I have.
To fix it could you just grind the offensice threads down and drill and tap the main stud and use a bolt and washer to hold the pedal to the stud?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 09 Jun 2008 08:48 by StreetfighterKz.
- patmann
09 Jun 2008 09:09 - 10 Jun 2008 06:21
Sandy wrote:
So it's not just me that can't tell?? I was thinking it was these 50 year old eyes. But if you young whipper snappers can't tell either..it must be Mother Kawasaki's drawing :blink:
Maybe tonight I look closer. Last night was NOT a good one.
To top it off I blew my halogen high beam on the Zed too.
AND one of my front turn signal lenses was hit by a rock and cracked into 50 million pieces.
But on the plus side, I'm single with out children this week. The wife and kids are off camping for a week.
I miss the kids already, the wife...well maybe by Friday;)
Last edit: 10 Jun 2008 06:21 by patmann.
- dnyce
09 Jun 2008 21:49
doug has the perfect fix. most likely wont even be able to tell that its different. or buy some tarozzi rearsets :silly:
- StreetfighterKz
10 Jun 2008 04:25
dnyce wrote:
Unfortunately, the Tarozzi's still require the use of that stud as part of their linkage setup.
Later, Doug
Later, Doug
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- shrap66
02 May 2018 16:30
Hi,
I am new to this community and just purchased a 1979 KZ1000 LTD I want to restore. I know this is an old thread but I was wondering if finally you were able to free up that brake pedal ?
Same situation for me. Seems DOT 4 fluid dripped on the brake pedal joint and it is stuck real good. The dome nut was stripped so I cut it off. I am down to the pedal, tried to lube it, heat it. I am able to move it up and down using a hammer but it is not moving horizontally at all.
I will try with a propane torch tomorrow.
Any tips would be appreciated.
Thanks.
Thanks.
1979 KZ1000B3 LTD Glacier Green
02 May 2018 21:20
A 1:1 mixture of acetone and ATF makes one of the best penetrants. I would try liberal doses of it over several days and then get after it with heat, hammers, pry bars and whatever else you have at hand.
The following user(s) said Thank You: shrap66
- shrap66
03 May 2018 06:03
ATF = Automatic transmission fluid ?
- slmjim+Z1BEBE
03 May 2018 07:15 - 03 May 2018 07:16shrap66 wrote: ATF = Automatic transmission fluid ?
Yes.
We call the 1/2 & 1/2 mix of ATF and acetone "Magical Mystery Fluid", or MMF for short.
We only stir up about 2oz. at a time. The acetone evaporates out of the MMF quickly, even when capped. If allowed to sit, it also begins to separate, with the ATF settling to the bottom. Just shake to mix it again.
Give it a few days to work. Renew the application often during those days.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 03 May 2018 07:16 by slmjim+Z1BEBE.
- shrap66
04 May 2018 12:49
Dudes !!!
I could barely move the pedal with a large hammer last night. I had bought the Acetone and ATF so I mixed it and applied large doses over 20 minutes, moving the pedal with the hammer and adding some more. I let her sleep like that.
This morning I was able the move the pedal up and down by hand only but it was still stiff. I mixed another batch and applied more.
Went back down to my garage at 3 and the lever was moving a lot better. Wiggle it out without even having to heat it or use a hammer. She was loose like my girlfriend before menopause. Which is why I will also be calling your mixture KZ KY.
Its now re-assembled and works like new.
You guys are awesome ! This really made my day. I was thinking about cutting the whole thing off yesterday.
Awesome. :woohoo:
Awesome. :woohoo:
- slmjim+Z1BEBE
04 May 2018 16:50shrap66 wrote: ...She was loose like my girlfriend before menopause....
Uummm... The Lovely Z1BEBE chuckled at this.
slmjim sez, " OP, hope your GF doesn't read the forum "
Together we say, "Professional use in a closed environment. KZ KY not a substitute for the real thing. Kidz, don't try this at home.":silly:
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
