z1R rotors
- NickW900LTD
- Nick
z1R rotors
08 Jun 2008 12:35
I want to know if these rotors are a direct bolt on. I figured since they were thinner some other part would have to be modded? Suggestions please.
Nick
Nick
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
1977 KZ1000 LTD
1978 KZ1000 A2A
- OnkelB
Re: z1R rotors
08 Jun 2008 13:23 - 08 Jun 2008 13:38
Can´t say for sure if the rotors are a bolt on as I´m not that familiar with the 900 Ltd, but the Z1R rotors have a 297 mm/11.69" diameter and a four bolt pattern.
As for the thickness, no other mods are needed - the service limit for the Z1R rotors is 4.5 mm, which is like 1.5 - 2 mm less than the thicker rotors, with a fresh set of pads you shouldn´t have any problems, plenty of piston travel left.
I´ve been running Z1R rotors using a pair of stock 650 calipers on my 650B for the past 3-4 years with no problems.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 08 Jun 2008 13:38 by OnkelB.
- SLEEPER650
Re: z1R rotors
09 Jun 2008 06:17
hey onkelb why did you install your lower tubes backward?
78 650sr my baby
78 650sr waiting for rebuild
82 kz1100
82 kz1100
- OnkelB
Re: z1R rotors
09 Jun 2008 07:18
SLEEPER650 wrote:
The 650 B1 is born with a single disc and the caliper in front of the fork leg. When I installed the dual discs I wanted the calipers behind the forks, so I switched the fork legs and flipped them around.
