Swing arm removal
  • SuperTrey
  • SuperTrey's Avatar Topic Author
Swing arm removal
08 Jun 2008 07:38
#218704
I have a 1982 KZ1100 D1 that I am parting out.
How do you separate the drive shaft from the drive unit at the motor end? It is a splined shaft on the motor side, and i can't see any type of bolt or pin holding the ujoint on it, it wiggles like it wants to come loose, but it doesn't just slide off like a car drive shaft.
How do you pull the stubby swing arm shafts? It appears that you have to thread a bolt into the center after the cover plates are removed and extract them?
Anyone need parts from this bike?
Thanks for your help!
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Swing arm removal
08 Jun 2008 09:24 - 08 Jun 2008 09:25
#218715
There is a pin that holds the shaft in place, press it in and the shaft pulls off. On my 750 I have to remove the clamps on the rubber boot and shove the boot around, then find the pin and press it down, pulling off the shaft.
I'm sorry, I can't help with the other question.
Cashion, OK
78 KZ650 B2 85,000+ miles
Last edit: 08 Jun 2008 09:25 by OKC_Kent.
