handlebar size 1983 kz 750
- jon0108
02 Jun 2008 18:52
i need to buy new grips for my 83 kz 750 ltd. Does anyone know what size grips to get?
- steell
- jon0108
- JMKZHI
Last edit: 04 Dec 2008 06:35 by JMKZHI.
- jon0108
Re: switch assembly 1983 kz 750
03 Jun 2008 14:24
ok, my blinkers dont self cancel anymore. I did the test according to the factory service manual and have determined that the switch assembly is bad. Is there a way to repair the guts of the assembly or do i need to purchase the entire assembly
- ronjones
Re: handlebar size 1983 kz 750
03 Jun 2008 14:44
If it's the switch unit on the handle bars, sure take it off, open it up and check for broken/loose wires, clean the contacts, remove bug nests, etc. At the worst ya find ya can't fix it and your out a bit of time.
...or you can change the blinker fluid :blink: :laugh:
03 Jun 2008 17:17 - 03 Jun 2008 22:25
ronjones wrote:
This brand was useless, even when applied
in twice the recommended amount.
Last edit: 03 Jun 2008 22:25 by Patton.
Last edit: 03 Jun 2008 22:48 by Patton.
- jon0108
04 Jun 2008 05:25
wrong part , i need the assembly that goes on the left side of the handlebars
