KZ650C2 Rear Caliper details
- inline79
05 Feb 2006 17:17
Hi,
I'm having trouble locating literature on the KZ650C2's rear caliper. Does the rear wheel need to be removed in order to remove this caliper for a rebuild?
My rear caliper feels "loose" in place. I can shake it around by hand. It's been squealing, and the caliper moves a bit when the brake is applied. This all started after I flushed the fluid over the winter. It looks like the piston is what holds the caliper in place on the bike, and the rubber must be what is worn out.
www.buykawasaki.com doesn't have drawings for the C2's rear caliper, so I don't even know what parts I need.
- inline79
Re: KZ650C2 Rear Caliper details
05 Feb 2006 17:50
upon further inspection:
There are two bolts on the caliper itself. I'm assuming this just hold the two halves in place and there is just a single piston. Is it possible to remove these bolts to break the caliper in half and remove it this way?
- rstnick
05 Feb 2006 18:32
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
05 Feb 2006 18:33
And the diagram. It says '79 but it's for the 77 + 78.
Post edited by: rstnick, at: 2006/02/05 21:39
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- inline79
