Would you guys trust a tire plug?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Would you guys trust a tire plug?
02 Jun 2008 09:39
#217397
i use plugs in my backhoe tires but they rarely get over 25mph!:laugh: id say change the tire;)
  • riverroad
  • riverroad's Avatar Topic Author
  • 1980 1000LTD B4
02 Jun 2008 11:56
#217430
:laugh: This coming from the man most likely to put a 600ci blown injected alcohol motor in a backhoe.
  • PLUMMEN
  • PLUMMEN's Avatar
02 Jun 2008 17:56
#217499
ive been over my head in service calls for so long i dont even have time to think about hotrodding anything right now,that would be fun though if you could find a hydraulic pump that would hold up to it!:laugh:
  • 893cv
  • 893cv's Avatar
02 Jun 2008 21:11
#217535
I dont think the stock rims on a 1980 1000 LTD are tubeless rims, so you should be using tubes now!
1980 kz1000 LTD
1978 Z1R
  • riverroad
  • 1980 1000LTD B4
03 Jun 2008 04:24
#217570
893cv, my wheels do say tubeless right on them, and they sure look stock to me.
  • bountyhunter
  • bountyhunter's Avatar
03 Jun 2008 12:26 - 03 Jun 2008 12:29
#217677
saxjonz wrote:
Depends upon how big the cut is if it is a small puncture a tube will work just fine. Mechanics put tubes in tubeless tires all the time.
They sure do, they also fix "tube" tires with a plug and a new tube. I don't see any greater risk in plugging and tubing this tire.
The only caveat is that the hole needs to be more or less centered in the tread, not on the edge or in the sidewall.
Last edit: 03 Jun 2008 12:29 by bountyhunter.
