fork oil
  • KEN428CJ
  • KEN428CJ's Avatar Topic Author
fork oil
01 Jun 2008 20:01
#217277
can any body tell me how much fork oil to use on 1979kz1000 LTD thanks
  • PLUMMEN
  • PLUMMEN's Avatar
Re: fork oil
01 Jun 2008 20:44
#217284
around 180 if you completely emptied the forks.i prefer the 30w synthetic motor oil over the 15w myself ;)
Re: fork oil
01 Jun 2008 21:10 - 01 Jun 2008 21:15
#217289
Per FSM for 1979 KZ1000-A3 (standard model) and D2 (Z1R-II Cafe Racer): fork oil level with front wheel suspended off ground and spring removed is 441mm from top of inner fork tube. Refill when completely dry after reassembly is 180-188cc. FSM cautions not to overfill.
Please note the mentioned FSM does not purport to cover the 1979 KZ1000-LTD. Would guess the LTD likely has same specs, but truly don't know. The A3 and D2 front axles fit directly under the lowers. Don't recall whether the LTD front axle might be located on front side of lowers, but if so, such different fork design may make a difference in the fork oil specs.
Good Luck! :)
Edit -- Believe the LTD axle is also located directly under the axle.
Last edit: 01 Jun 2008 21:15 by Patton.
  • bountyhunter
  • bountyhunter's Avatar
Re: fork oil
01 Jun 2008 23:19
#217306
So did I back when I was young... now I run the stock weight.:laugh:
Heavy oil really makes them stiff.
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: fork oil
02 Jun 2008 00:47
#217310
As has been suggested by other members, 180-188 ml (cc)/fork...this is verified by the 1979B3 FSM supplement:)
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
