Lester mags .. tubless or tube??
  • brich
  • brich's Avatar Topic Author
30 May 2008 18:04
#216853
Hey all -
I searched the forum thinking this was probably asked before. I found some debate, but was still confused on a definitive answer.
Are Lester mags tubless or tube? I have a pair I just finished polishing and painting and just bought some tires for. To keep it safe I got some Conti tube or tubless. One of the rims had a valve stem in it when i got it so i assumed they were tubeless, but then reading some old posts here has led to believe they may not be.
I am sure some of you have lesters on your bikes and figured I would ask in case I need to go run out and get some tubes as well.
- brian
1975 Z1 900, 1075 wiesco kit, web cams, smooth bores, dyna ignition, denco pipe, lester mags, wicked bad rotors, custom gauge face plates .. not much stock left.
Re: Lester mags .. tubless or tube??
30 May 2008 19:19
#216876
My Lesters require tubes. Am guessing they all do. :)
[Click on image to enlarge]
  • RonKZ650
  • RonKZ650's Avatar
31 May 2008 07:49
#216934
Mine are tube type too.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
31 May 2008 08:53
#216940
Should there not be a casting in the rim stating tube type or tubeless, or TL. Something to that effect?
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • brich
31 May 2008 22:35
#217049
Well based on all of your info, and my lack of TL or Tubeless marks, I am really glad I ordered the tube or tubeless type tires! Thanks guys.
- brian
