Please help, 73' Z1 fork rebuild gone bad !
  • superboosted
  • superboosted's Avatar Topic Author
  • not new to motors/but surely new to this one!
30 May 2008 14:20
#216819
Well...I am sort of restoring a Z1 for a very good freinds father,as it is his last wish to ride his old bike that had been sitting for atleast 10 years. :(
Heres the problem---I took the fork apart to clean it,new seals and dust boots.Filled it with ten weight.Now it just feels sticky and you can almost lock it down.Also drained it and tried atf,same deal.
Instead of going uuuuppp-dooowwwnn it goes u-u-u-u-p- d-o-o-w-n.. :blink:
Thanks in advance,I have about 60hrs in this bike and would just like to be done,so I could actually ride my own. :silly:
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Please help, 73' Z1 fork rebuild gone bad !
30 May 2008 14:54
#216826
Any possibility the tubes are bent?
Cashion, OK
78 KZ650 B2 85,000+ miles
  • FastKaw1
  • FastKaw1's Avatar
30 May 2008 15:09
#216829
As long as you put them back together right, there not much to them
so I duet that.
My first guess would be the springs. If they are OEM and bin
under a compression for all those years there probably (bound)
Was the top cap hard to put on or did the spring stick up past
the top of the tube?
XENU
  • superboosted
30 May 2008 18:22
#216856
Actually the spring is level with the top of the fork tube with the fork fully extended.
I have done them before...I can't imagine they are bent.They weren't before. ;)
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
30 May 2008 19:33 - 30 May 2008 19:40
#216878
Sometimes it helps to loosen the axle clamps and then work the forks up and down allowing the lowers to re-set onto the axle. And assure the clamps are properly oriented (arrow pointing forward) before re-tightening, with gap in the rear and no gap in front.
Could also test fork action with front fender bolts loosened, to see whether fender fitment is somehow binding the lowers from being in the correct positions.
Also sometimes helps to loosen all the fork clamps and then retighten them.
Good Luck! :)
Last edit: 30 May 2008 19:40 by Patton.
  • FastKaw1
  • FastKaw1's Avatar
31 May 2008 05:35
#216924
Try 20 weight. Pump them at least 20 times.
I don't recommend this, but you could shim the spring at the top.
A pice or 3/4 conduit 3/4 to 1 in. long between the spring and cap.
Found them that way lots of times. Cheep way to stiffen them up I guess.
XENU
  • superboosted
31 May 2008 10:54
#216952
Thanks guys...I will try all of these ideas. B)
Unfortunately I got it running last night and there is something rattling in the gearbox. :(
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
  • FastKaw1
  • FastKaw1's Avatar
31 May 2008 12:32
#216964
If it's setting a long time you may have broken a couple of clutch plats on
first start up. easy fix Id check that first.
