front forks
  • buckracer24
  • buckracer24's Avatar Topic Author
front forks
04 Feb 2006 20:15
#21542
if you were to cut the springs in the front forks,is this an way to lower the front of the bike for drag racing?or does this do some nasty things?
thanks
Jody
  • wireman
  • wireman's Avatar
Re: front forks
04 Feb 2006 21:29
#21552
try slugsB)
  • Snakebyte
  • Snakebyte's Avatar
Re: front forks
05 Feb 2006 01:22
#21578
If you cut the springs in the forks it will just make it a stiffer ride due to the lenth of the spring being shorter. It will also just make the spring compress at a low weight.
Why dont you slide the tube up in the triple.:)
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: front forks
05 Feb 2006 06:59
#21609
Put spacers inside the fork tubes ,, It will make for a harder ride , Will add to performance ..Cutting or shortening springs is not really the way to go .. :) You can use PCV pipe cut to what you want to lower the bike ,, Here is the hard part though , You have to take the front forks apart to side your spacers over the fork tubes but under the seals ,, Might think of installing new seals at that time ,, :S But I am sure you already know that :dry:
  • buckracer24
Re: front forks
05 Feb 2006 09:10
#21639
ok thats cool thanks for the info,what are the dimensions of these spacers?
thanks
Jody
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: front forks
05 Feb 2006 10:52
#21668
Hey Buck,
First of all what sort of forks are you trying to lower? If they're old KZ's the simplest adjustment is to slide the tubes up in the clamps.
Shoe, You've got me confused. The spacers you're talking about are used to match or adjust a given set of springs in different length tubes. You could remove the stock spacers and replace them with longer ones for a stiffer ride. Or you could replace them with shorter ones for a softer and perhaps lower ride. Classically the spacers are dropped in on top of the springs and don't have anything to do with the seals.
Am I missing something?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • SquatchAirClutchSystems
  • SquatchAirClutchSystems's Avatar
Re: front forks
05 Feb 2006 11:29
#21674
No...you have to disassemble the forks and ADD a spacer to lower the ride height. Did it on my dragbike. I recommend aluminum rather than PVC though.
Shoe...I'm from Mansfield, too.
Mike :P
  • donthekawguy
  • donthekawguy's Avatar
Re: front forks
05 Feb 2006 12:58
#21692
I used the lowering kit from schnitzracing.com I had to cut the springs to get it back together though. Looks cool lowered 2 inches!
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • buckracer24
Re: front forks
05 Feb 2006 13:23
#21695
i already did the triple tree thing but i want to go lower still,you only get about an inch or so with the trees.
  • wireman
  • wireman's Avatar
Re: front forks
05 Feb 2006 13:30
#21696
slugs:whistle:
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
Re: front forks
05 Feb 2006 15:01
#21707
OH I get it.
You're putting a spacer between the damper assembly and the bottom of the fork tube so the forks can't extend fully.
Do you then leave out the top spacer if one is used?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • Shoe48
  • Shoe48's Avatar
Re: front forks
05 Feb 2006 21:29
#21793
You might have to cut the tops the same length as your new spacer trial will tell all ,, Hey Mr Airclutch give me a write .. would love to see what your up to .. ?:) Thanks for getting my advise straight guys ..:)
