Chassis setup and wheel alignment.
- TexasKZ900
22 May 2008 15:39
I have a 1976 KZ900 project that I need some advice on. I’m using the front end and both wheels from a 1995 ZX7 and the swing arm from a 1989 GSXR.
I need to know if the back wheel is 6mm offset to the right side of center, will that hurt the bikes ride or performance?
- Makarth
Re: Chassis setup and wheel alignment.
22 May 2008 16:02
i don't think it would in a straight line but you could shim the wheel back to center where the pivot bolt for the swing arm is but thats just a thought off the top of my head.
- TexasKZ900
22 May 2008 16:16
Thanks for for the info, I thought of doing that on the swingarm but I would need to cut about 4mm off the left side and I don't know if the bearing would fit back in.
- steell
22 May 2008 18:58
You can't use spacers to move the wheel over, then mill the sprocket mount down to get your chain alignment?
- Makarth
22 May 2008 23:41
yea or depending which side it's offset to, shim it over and use an extended output sprocket. As for the bearings, i don't know if they have a tapered race inside the swingarm or if it's something else but if it's a race and you have access to a mill it wouldn't be too hard to redo a new race. just my thoughts
- StreetfighterKz
23 May 2008 04:54
I'm with Steell. Don't mill the arm just in case you ever want to swap wheels. You may be able to get way with milling the seal lip off your sprocket carrier and use a sealed bearing. The ZX wheels tend to be wider through the hub than a Gsxr rim is so that's why your rim is shoved over. BTW, the Gsxr swingarm uses needle bearing.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
