Front master cylinder
  • kneedragger80
  • kneedragger80's Avatar Topic Author
16 May 2008 10:31
#214030
Looking for some help identifying this master cylinder piston. It has a point and small plastic cap on the spring end. The reservoir is labeled 1/2".
This supposedly came off a KZ750. Maybe a single disk setup?
80 KZ750E
84 GPZ1100
NY US
. . . I used to do a little but a little wouldn t do it so a little got more and more . . .
  • kneedragger80
Re: Front master cylinder
16 May 2008 10:32
#214031
And the reservoir . . .
80 KZ750E
84 GPZ1100
NY US
  • snorules
  • snorules's Avatar
16 May 2008 22:03
#214143
Good luck on finding parts, I ended up putting a ninja master cylinder from ebay on my 550 LTD. I talked to Jeff at Z1, he said that there are no rebuild kits avalable for this cylinder due to it being used on only a few bikes. and I found this out after spending 3 hours smoothing and polishing mine:(
1980 KZ550C (daily rider)
1981 KZ1000J (bagger project in progress)
1981 GS1100 (future dragbike)
1978 Z1R (not mine yet, but trying to work out a deal to acquire it).
  • kneedragger80
18 May 2008 05:33
#214277
Just got word from Rob at Z1 that its from an 80650E or F - and you're right, rebuild parts are very hard to come by.
You mentioned you replaced your's with a Ninja master cylinder, mind if I ask what year and model?
Thanks
80 KZ750E
84 GPZ1100
NY US
  • steell
  • steell's Avatar
18 May 2008 06:59
#214293
Most of them will work, you just need to make sure that it has the threaded hole for the mirror to screw into. I have a 95-96 GPz1100 master cylinder on my 79 KZ750 twin, along with 79 KZ1000 drilled rotors, 83-85 GPz750 calipers, and braided stainless steel lines.
GPzInfested can out run me on his 750 Turbo, but he can't come anywhere close to stopping as fast as I can :D
