What swingarm?
  • badrhino
  • badrhino's Avatar Topic Author
What swingarm?
16 May 2008 09:12
#214010
Hi, just wondering what swingarms fit the 1980 KZ1000 with little or no modifications.
I would like to put a different one on so I could go wih a wider rear wheel. It isn't really necessary but I thought it would look better with a wider rearend.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: What swingarm?
16 May 2008 09:15
#214011
suzuki gs 1100 is a popular swap.you can search for gs 1100 swap,i think.it has been covered a couple times
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: What swingarm?
17 May 2008 05:19
#214160
Earlier Suzuki Gsxr arms also fit without alot of mods. You will have to decide on if you want to mono-shock or keep your twin shock.
My in progress 900 monoshocked..
kzrider.com/index.php?option=com_kunena&...=11&id=208052#208052
My 1000 with twin shocks..
kzrider.com/index.php?option=com_kunena&...=11&id=155488#155488
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • badrhino
Re: What swingarm?
28 May 2008 15:45
#216464
I have a few used swingarms that I am considering. I was just wondering what the measurments was for the original swingarm so I could decide wich would be the best fit with little modifications.
I have :
1998-2003 Suzuki TL1000R
2003 Kawasaki 636
2004 Yamaha R1
89-97 Kawasaki ZX-6R
Franken Z!
  • StreetfighterKz
Re: What swingarm?
28 May 2008 18:28
#216487
I think that the stock arm at least on the slightly older model Kz900/1000 are 235mm across at the pivot and use a 16mm (I think) pivot bolt.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
