what model is this ??
  • woodyskz
  • woodyskz's Avatar Topic Author
04 Feb 2006 04:57
#21399
the motor has the # KZ650 B , THE FRAME HAS THE # kz650 C. IT IS A '77 . WHAT MODEL IS THIS ? THANKS TO ALL THAT HELP.:blink:
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: what model is this ??
04 Feb 2006 05:24
#21403
If it is a 'C' frame number then it is a 'C' model. Motors (for the B and C models) didn't apparently differentiate with model specific numbers. The info on this site for the 1977 C model is in error with respect to VIN info, they are reversed. There is apparently no info on the 650 series on zedder.com!
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
04 Feb 2006 07:28
#21413
Check out this site: 650 models .
As Mcdroid said though, the frame and engine #s are reversed.
Post edited by: rstnick, at: 2006/02/04 10:28
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • woodyskz
04 Feb 2006 08:00
#21422
thanks for the info & quick reply mcdroid .
  • woodyskz
04 Feb 2006 09:38
#21430
thanks also rob for your reply..
  • reborn650
  • reborn650's Avatar
04 Feb 2006 10:18
#21437
My '77 650 Custom is the exact same as yours with different year and engine serial # series. Perhaps Kawasaki pulled the engines from the production line early to pop into the later frames? Just a thought.
-1998 Jeep TJ Wrangler 4.0 litre for the kids
-1975 Zamboni - The real Italian sportscar fully restored and functioning every winter at our local outdoor playground rink.
Mine is an ecclectic collection of motorized toys - LOL
I have a newspaper route and a web site where you can plan your own funeral life celebration www.mysendoff.com ....and go out with your own style.
  • OnkelB
  • OnkelB's Avatar
05 Feb 2006 12:23
#21683
If it has wire wheels, single disc front brake with the caliper in front of the fork and a rear drum brake it´s a B1 - if it has mag wheels, twin disc front brake and rear disc it´s a C1, provided it really is a 77.
B1 and C1 use the same engine which differs from all other 650 models in that it uses a different charging system, B1 and C1 use excited field alternators, the rest use a permanent magnet setup. If you look at the alternator cover (right in front of the gear shift lever)and there are three bolt heads visible in the center of the cover you have the excited field type (making it a 77), the three bolts hold the field coil.
Post edited by: onkelb, at: 2006/02/05 15:30
77 KZ 650 B1, 82 GPz 1100 B2.
