new chain
  • leitrum
  • leitrum's Avatar Topic Author
new chain
16 Oct 2005 17:31
#2139
how do you feed the chain through the front sproket? do i hook a link through the new and old chain and feed new through???????????????????????help
  • DanOz7Five0
  • DanOz7Five0's Avatar
Re: new chain
16 Oct 2005 18:10
#2152
Without knowing your exact model Im just going to say to remove the sprocket cover and you will see the sprocket there. There may be a safety guard by the cover with 3 10mm bolts, remove that and you may be able to slip the chain on the sprocket.
  • Biquetoast
  • Biquetoast's Avatar
  • King Jeremy The Wicked
Re: new chain
16 Oct 2005 18:11
#2154
You have to take the cover off to get to the front sprocket.
Hmm... and from the way you worded this, I have to assume you didn't replace your sprockets. I don't know if you know this, but if you put a new chain on old sprockets, it's just going to stretch it right out.... :unsure:
(1.) '75/'76 KZ400D - Sold
(4.) '75 KZ400D - Sold
kz750twins.com
  • leitrum
Re: new chain
17 Oct 2005 02:46
#2282
sorry always forget the stats. 81' kz 440 b
  • leitrum
Re: new chain
17 Oct 2005 02:51
#2283
the sprokets only have 4000 miles due you really think they need to be changed? only have bike a month still rebuilding, but decided since was sitting since 88' to change chain. it seemed fimed fine just a precaution, but never even thought about the sprokets.
  • steell
  • steell's Avatar
Re: new chain
17 Oct 2005 04:13
#2292
The sprockets should be fine, the chain was probably good as well :)
  • Biquetoast
Re: new chain
17 Oct 2005 06:55
#2315
My bad, I assumed that you were changing the chain because of it exceeding the service limit for wear/stretch. So you're just replacing it because its rusty? That's fine... nevermind what I said about sprockets...
kz750twins.com
  • RonKZ650
  • RonKZ650's Avatar
Re: new chain
17 Oct 2005 18:17
#2411
If you elect to replace only the chain and not the sprockets, yes, just tie your new chain to the old one using a masterlink and pull it right around the sprocket.
