Lower bearing race - How do I get this off? - pic
- dutchz
03 Feb 2006 20:30
Can't get the bottom race off. There's a thin spacer/ring all the way on the bottom, then rubber ring and then the bottom race that the bearing balls sit in. What is the best way to pry this off? I will be installing roller bearings so I'm guessing these rings need to go?
Thanks
Thanks
1974 Kawasaki Z1
Stock front hub and rear axle.
- OKC_Kent
Re: Lower bearing race - How do I get this off? - pic
03 Feb 2006 20:51
I put in tapered bearings last week, I don't recall any problem getting it off. I pried it up with a big screwdriver blade. It did ruin the rubber seal. Remove them all you won't need them.
Cashion, OK
78 KZ650 B2 85,000+ miles
- Fossil
03 Feb 2006 21:31
I had to crack one to get it off with a small very sharp cold chisel after fighting with it for a few evenings. It wouldn't budge with a screwdriver, a screwdriver and hammer, or propane torch, screwdriver and bigger hammer. I wasn't going to grind it off and make a mess of everything. Cracking it was easy.
- KZQ
- Administrator
Re: Cheap wood chisel.
04 Feb 2006 05:41
Pick up a cheap wood chisel and with the bevel toward the bearing drive it in between the lower triple clamp and the stem. Work your way around. It'll move.
KZCSI
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- OKC_Kent
04 Feb 2006 08:51
Fossil wrote:
A few evenings, whew. I had it easy i guess. Mine was off in less than a minute.
Cashion, OK
- wireman
04 Feb 2006 10:26
pickle fork,they also make a tool for it ive seen pictures of but i dont have one.
- Snakebyte
05 Feb 2006 01:36
I use a cut off wheel. Grind a slot in the race, but not all the way through. Hit the race with a chisel and it will crack it then just slide it off.
- arobsum
05 Feb 2006 09:21
like old bearings, crack one edge and pry it off. these guys are right. easiest way to go.
- dutchz
06 Feb 2006 00:05
I'm cutting a slot in it on one side with a dremel, and will hit it with the cold chisel. We'll see what happens...
1974 Kawasaki Z1
- wiredgeorge
06 Feb 2006 07:26
If prying doesn't work, use a cut off wheel and don't bother with a slot. You ain't gonna want to save it anyway.
