81 750ltd swingarm swap advice needed
  • KZPens
  • KZPens's Avatar Topic Author
13 May 2008 19:42
#213435
I got a '93 ZX7 swingarm a couple of month ago to swap into my 81 750LTD, well I finally decided to do, it was too much fun riding... and I was working on my other project, a naked 83 GL1100 Goldwing
Anyways I was thinking about drilling out the holes for the pivot bolt, but I don't think I could drill them straight and would most likely mess things up.
So I was reading in older posts how some got a sleave made to use the KZ bolt in the new swingarm, I think this is how I want to go about it. What would be a fair pricerange to have a sleave made and what material should be used ?
And I want to keep the dualshock setup what would be a fair pricerange to have the shockmounts made and welded onto the swingarm ?
I already checked to make sure the chain will clear the frame and I know I'll need an offset 530 sprocket/chain.
Anything else I'm not thinking of?
Thanks for any advice.
Link to project Link: Link
  • steell
  • steell's Avatar
Re: 81 750ltd swingarm swap advice needed
13 May 2008 20:20
#213448
Can't give you exact numbers, but if you go to a machine shop and ask them to make you the appropriate sleeve, It will probably cost you $100-$150.
Since the bearings ride on the sleeve, it probably should be hardened, I think case hardening will probably work, since you just need the surface hardened where the bearings ride.
The diameter of your original pivot bolt is 16mm. what diameter is the new one?
I'm putting a GPz750 swingarm on my 80 KZ750E, and the KZ750E has a 16mm pivot bolt also, while the GPz750 has a 17mm pivot bolt. I have a 17mm drill, and although we used it on GPzInfested's KZ650/GPz750 swingarm, I don't like the results so I'm not doing mine that way.
I'm making a boring bar that uses HSS cutting bits that will be 16mm on the end (to fit in stock size and be a guide) and then stepping it up to 17mm, so that part will act as a guide after the hole has been enlarged. The boring bar will be 1/2" on one end to fit in a 1/2" drill motor.
Since I have to widen the frame about 1/8" between the pivot bolt holes, I am also putting another place for a bit on the 17mm section to act as a facing cutter to cut the face of the bolt holes 1/16" on each side.
It's harder to make it and describe it than it is to use it, and It's really a limited use tool (not a big call for it).
I was in the shop till 3 am this morning working on it, turning a hot rolled steel bar down to .667 and .627 22" long between centers is virtually impossible without a follower rest, or at least a steady rest, and I have neither. And turning hot rolled steel really sucks, that stuff is nasty to work with, I'm thinking about looking for a piece of cold rolled round bar, maybe 1018.
  • KZPens
13 May 2008 21:08 - 13 May 2008 21:43
#213466
The pivot bolt is quite large with a 25mm diameter, it's hollow... and the inside it too large 18mm or I might have been able to use the bolt as a sleeve... would have been to o easy.. :laugh:
Yeah boring bar makes sense, sure is nice to have the tools to make one, and the skills.
With a 100 to 150 bucks the sleeve would be the second most expensive item I bought for the bike :woohoo: , guess I'll have to fork over the cash, at least the swingarm was only $10.
Edit: I was just googling 18mm outside and 16mm inside diameter and got a result that says 1/2 inch waterpipe has actually these dimensions :huh: ?? Is this something I could work with?
Last edit: 13 May 2008 21:43 by KZPens.
  • jordan
  • jordan's Avatar
13 May 2008 21:44
#213475
I had my local welding/machine shop make my sleeve. I gave them the stock swingarm bolt and the swingarm. I simply told them to make a sleeve that will fit nicely into the swingarm, with a hole hollowed out down the middle that will tightly fit this swingarm bolt. Cost me exactly $98. I was very satisfied with the outcome, and it worked great.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • cmmman
  • cmmman's Avatar
13 May 2008 22:44 - 13 May 2008 22:45
#213483
Using your existing 25mm pivot bolt as a sleeve may work. I would make 2 short sleeves instead of making one long one, using the 18mm OD and 16mm id. Then cut the 25mm pivot bolt to the same length as the width of the new swing arm and and slide the sleeves in each end and have them welded in.
As for the water pipe, if it is precision tubing with 18mm OD and 1mm wall it may work if it is a material durable enough.
1977 KZ650B, modified.
Last edit: 13 May 2008 22:45 by cmmman.
  • KZPens
13 May 2008 23:12
#213486
I'll drop by the hardware store in the afternoon and see what they have and how tight a fit it would be. If not a $100 doesn't sound too bad, then again I bought my other projectbike for that much.. :S
Thanks all.
  • steell
  • steell's Avatar
14 May 2008 06:38
#213518
I don't know what you mean by "water pipe", but if it's the iron pipe it's galvanized and has a wall thickness of 1/8" (little over 3mm).
Galvanized means it's zinc plated, and you don't want needle bearings riding on zinc plating, the zinc will flake off and destroy your bearings in a short time. Standard 1/2" iron water pipe is supposed to be approximately 12.5mm ID and 19mm OD. And after having just cut and threaded a bunch of 1", 3/4", and 1/2", iron pipe for the air lines in my shop (overkill, but it was free), I can assure you that the wall thickness is much more than 1mm :)
