Rear tire
- tool maker
Rear tire
11 May 2008 19:34
I would like to mount a 140/90 16 mezteler on my 82 CSR 1000, Stock tire size is 130/90 16 and the rim is 3.00 wide.
Has anyone done this before or see any problems with it fitting.
Thanks for any info.
Doug.
Doug.
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
- Sandy
- Fly High,Tony
Re: Rear tire
12 May 2008 09:23 - 12 May 2008 09:28
A 140 might be a bit tight.
You'll get SOME tire-flex in corners,and that size tire is probably going to touch the inside of the swingarm.
From what I've gathered here,over the years,a 140 probably IS going to be too wide.
I too,am running a 130 with no issues.
1977 KZ1000 A-1
Last edit: 12 May 2008 09:28 by Sandy.
- tool maker
Re: Rear tire
12 May 2008 18:31
I thought the 140 might be a bit wide, just wanted it for looks. I think I'll stick with the 130, Thanks for your opinion.
Lancaster, PA
