Oh CRAP! Zx6r 530 Rear Sprocket Nowhere....
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
10 May 2008 08:27
#212541
Hey all,
While thinking about this I just realized a possible HUGE screw up in my project.
KZ900 swingarm converted to 2003/2004 ZX6rr. (5.5" rim w/180mm tire)
KZ900 is designed around a 630 chain/sprockets.
ZX6rr is designed for a 520 chain/sprocket.
Here's the "Oh CRAP" I just realized....
KZ Offset Counter sprockets are available in 530 or 630 sizes. The ZX6r/rr rear sprockets are only available in 520 sizes.
Preference would be due to chain width and clearance issues is to have a 520 offset counter sprocket. Tensile strength is a concern but with new chain technologies, a 520 chain now has over 9000 lbs strength.
damn it, damn it, damn it, damn it, damn it, damn it:woohoo:
Anyone have any ideas other than get drunk?
NOTE: I have already e-mailed Kosman and Precison regarding a custom 520 counter sprocket.
Anyone out there found a rear 530 sprocket that would fit a ZX6r?
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • steell
  • steell's Avatar
Re: Oh CRAP! Zx6r 530 Rear Sprocket Nowhere....
10 May 2008 08:55 - 10 May 2008 09:22
#212545
www.sprocketspecialists.com/
Download their catalog and look at the sprocket specs for the year and model bike that your rear wheel came off of, then look for a sprocket with the desired chain pitch that matches the specs.
They are the only place that supplies sprockets for my rear Morris Mag that I have found.
Around $60-$70 though :(
I just looked and they don't list the sprocket specs any longer :(
You'll have to call and tell them you have a 2004 ZX6 RR and you need a 530 sprocket, if they don't have one they'll make it for you.
This is funny :D
Just on a whim I checked the specs for a 76-79 KZ750 twin sprocket, and guess what? The specs (bolt hole diameter, bolt circle diameter, center hole diameter) are exactly the same as a ZX6 RR, and the 76-79 KZ750 twin is a 530!
I checked the specs at JT sprockets, at least they still list them.
Problem solved :)
Last edit: 10 May 2008 09:22 by steell.
  • Old Man Rock
10 May 2008 15:53 - 10 May 2008 15:55
#212594
Hey Steell,
Thanks for the link, I've sent them an e-mail inquiry. As far as I can tell, they only make rear sprockets, couldn't find NON OEM counter sprockets on their site. Hopefully I'm wrong.
$60 - $70 for a rear 530 sprocket would be cheap... B)
I'd be good with that price.
Same time, I have other inquiries out for Kosman and Precision to see If I can get a KZ900 520 counter sprocket fabricated. Outside of tensile strength concerns that I feel the new chain technologies would be fine, this would shave a much needed 1/8" clearance.
Are you serious????
Oh well, have to wait and see otherwise I'm screwed! :blink:
Thanks again,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 10 May 2008 15:55 by Old Man Rock.
  • steell
  • steell's Avatar
10 May 2008 17:16 - 10 May 2008 17:27
#212609
From the JT Sprockets catalog.
ZX6RR 03-04
KZ750 twin 76-79
Might have to grind those two notches on the ID of the center hole, rat tail file or a dremel would make short work of that though. I have several worn out 750 twin sprockets, pay for shipping and I'll send you one so you can try it out before spending the $40 or so for a new one.
Sprocket Specialist will make you a custom rear sprocket, for a front sprocket if you take a 900/1000 630 sprocket and an appropriately sized 520 sprocket to your local machine shop, they should be able to cut and weld the two together. Might be a little pricey though.
Last edit: 10 May 2008 17:27 by steell.
  • Old Man Rock
11 May 2008 08:15
#212767
Steell,
KZ750 twin 76-79... For $40 (530) I'd give this a try...
I Still want to see if a 520 counter sprocket is an option for I could use the 1/8" shaving.
Excellent & Thanks,
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
