"Rattle Sound" every time I Rev the Engine
07 May 2008 16:12 #211895 by SPARTAN
Bike:81' KZ750 inline-4
Everytime I Rev up the engine I get a annoying rattling sound like there is something floating around inside. I believe the sound is coming from my clutch or around that area.
Have you guys had a similar problem? It a really annoying sound.
Thanks,
Anthony
07 May 2008 16:36 #211907 by Sandy
Replied by Sandy on topic "Rattle Sound" every time I Rev the Engine
Any history on the bike that you can tell us about?
How many miles?
What have you done to the bike,as far as mantenance,etc.?
1977 KZ1000 A-1
07 May 2008 16:59 #211916 by SPARTAN
Replied by SPARTAN on topic "Rattle Sound" every time I Rev the Engine
How many miles?
I'm the Second Owner The bike had about 6,000 miles on it when I bought it, now it has about 10,000 miles.
I tune up the bike regulary, I just changed(about two weeks ago):
the spark plugs
oil
oil filter
Air Filter is new
I've rode it pretty hard when I got it other then that everythings ok.
07 May 2008 17:04 #211920 by Sandy
Are you familiar with the cam-chain tensioner at all,or the clutch cover(right hand side of engine when sitting on bike).
I've heard of the clutch-hub springs getting weak and causing noise.
The cam-chain adjuster would be the easier check,to start off with.
Do you have a manual for that bike?
1977 KZ1000 A-1
08 May 2008 11:30 #212058 by 79MKII
Replied by 79MKII on topic "Rattle Sound" every time I Rev the Engine
Is your emissions junk still installed? If not, is everything properly plugged up? There's a valve under the tank that makes a lot of noise if it's not plugged up. Looks kind of like a pcv valve. Hopefully it's something simple and not much worse.
The Kaw List:
09 May 2008 14:13 #212386 by SPARTAN
Yes I have a well referred to manual. My co-workers and I were thinking it was something simple like a chain adjustment. I'm going to check that out this weekend and let you guys know if that fixed it.
The clutch-hub springs? Sounds like that could be something to check out.
09 May 2008 14:21 #212388 by mjg15
Replied by mjg15 on topic "Rattle Sound" every time I Rev the Engine
Does it rattle when the rpm's are increasing or decreasing ?? Both ? . Camchains seem to make their rattle when the rpms are decreasing .
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
12 May 2008 19:48 #213170 by SPARTAN
It seems like a little of both. But it tends to make the awful "rattle" sound when I'm accelerating.
12 May 2008 20:05 - 12 May 2008 20:07 #213176 by Patton
Replied by Patton on topic "Rattle Sound" every time I Rev the Engine
SPARTAN wrote:
...tends to make the awful "rattle" sound when I'm accelerating.
Possibly pre-ignition pinging? Could double-check ignition timing. Also wondering if standard NGKB8ES sparkplugs are installed (and not some hotter higher heat range plugs).
Done a plug reading? What did old plugs look like?
Good Luck! :)
Last edit: 12 May 2008 20:07 by Patton.
12 May 2008 20:10 - 12 May 2008 20:11 #213177 by Patton
Would also double-check drive chain condition (kinking?)-- properly lubed -- and proper slack adjustment. :)
Last edit: 12 May 2008 20:11 by Patton.
12 May 2008 20:22 #213182 by SPARTAN
So I'm referring to my manual and the "rattle appears to be the "ball lock tensioner" associated with the Cam chain and tensioner.
The manual says in order cure the problem I need the "cross wedge tensioner"
So I hope BikeBandit.com has one of these things available(I need a new head gasket too).
Thank you guys for helping me find the problem!!
12 May 2008 21:27 #213213 by Patton
Might be another option --
Ape cam chain tensioner from Z1E
Good Luck! :)
