"Rattle Sound" every time I Rev the Engine
- SPARTAN
07 May 2008 16:12
Bike:81' KZ750 inline-4
Everytime I Rev up the engine I get a annoying rattling sound like there is something floating around inside. I believe the sound is coming from my clutch or around that area.
Have you guys had a similar problem? It a really annoying sound.
Thanks,
Anthony
Thanks,
Anthony
- Sandy
- Fly High,Tony
Re: "Rattle Sound" every time I Rev the Engine
07 May 2008 16:36
Any history on the bike that you can tell us about?
How many miles?
What have you done to the bike,as far as mantenance,etc.?
How many miles?
1977 KZ1000 A-1
- SPARTAN
Re:
07 May 2008 16:59
Sandy wrote:
I'm the Second Owner The bike had about 6,000 miles on it when I bought it, now it has about 10,000 miles.
I tune up the bike regulary, I just changed(about two weeks ago):
the spark plugs
oil
oil filter
Air Filter is new
I've rode it pretty hard when I got it other then that everythings ok.
How many miles?
the spark plugs
oil
oil filter
Air Filter is new
- Sandy
- Fly High,Tony
Re:
07 May 2008 17:04
Are you familiar with the cam-chain tensioner at all,or the clutch cover(right hand side of engine when sitting on bike).
I've heard of the clutch-hub springs getting weak and causing noise.
The cam-chain adjuster would be the easier check,to start off with.
Do you have a manual for that bike?
1977 KZ1000 A-1
- 79MKII
- Love Them Kaws!
Re:
08 May 2008 11:30
Is your emissions junk still installed? If not, is everything properly plugged up? There's a valve under the tank that makes a lot of noise if it's not plugged up. Looks kind of like a pcv valve. Hopefully it's something simple and not much worse.
The Kaw List:
- SPARTAN
Re:
09 May 2008 14:13
Sandy wrote:
Yes I have a well referred to manual. My co-workers and I were thinking it was something simple like a chain adjustment. I'm going to check that out this weekend and let you guys know if that fixed it.
The clutch-hub springs? Sounds like that could be something to check out.
- mjg15
Re:
09 May 2008 14:21
Does it rattle when the rpm's are increasing or decreasing ?? Both ? . Camchains seem to make their rattle when the rpms are decreasing .
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
- SPARTAN
Re:
12 May 2008 19:48
mjg15 wrote:
It seems like a little of both. But it tends to make the awful "rattle" sound when I'm accelerating.
Re:
12 May 2008 20:05 - 12 May 2008 20:07
SPARTAN wrote:
Possibly pre-ignition pinging? Could double-check ignition timing. Also wondering if standard NGKB8ES sparkplugs are installed (and not some hotter higher heat range plugs).
Done a plug reading? What did old plugs look like?
Good Luck!
...tends to make the awful "rattle" sound when I'm accelerating.
Good Luck!
Last edit: 12 May 2008 20:07 by Patton.
Re:
12 May 2008 20:10 - 12 May 2008 20:11
Would also double-check drive chain condition (kinking?)-- properly lubed -- and proper slack adjustment.
Last edit: 12 May 2008 20:11 by Patton.
- SPARTAN
12 May 2008 20:22
So I'm referring to my manual and the "rattle appears to be the "ball lock tensioner" associated with the Cam chain and tensioner.
The manual says in order cure the problem I need the "cross wedge tensioner"
So I hope BikeBandit.com has one of these things available(I need a new head gasket too).
Thank you guys for helping me find the problem!!
