Brake Lever Swap out Steps
  • KOOL RYDER
  • KOOL RYDER's Avatar Topic Author
  • KZ 650B2 / KZ 1000E
07 May 2008 08:42
#211774
I want to install a new brake lever and have no experience doing this.
I ordered a new brake lever and it has arrived, but I do not just want to pull the old one witout some idea of how the process works.
Is it as simple as unscrewing the bolt and swapping the new on in its place.
Please help with a step by step solutionB)
Rockin\' a KZ650B2 since 2007 and a KZ 1000E since 2008
1978 KZ650B
1979 KZ1000ST
  • vach
  • vach's Avatar
Re: Brake Lever Swap out Steps
07 May 2008 10:00
#211788
Turn the adjuster in to give you some slack and then unbolt, pull out the cable and then reverse to install.
1979 kz650 B. Chicago, Illinois
  • RonKZ650
  • RonKZ650's Avatar
07 May 2008 10:04
#211790
If you're doing the front lever, it is just a simple unbolt the old, bolt on the new. If you're doing the rear, it's the same thing however the lever will probably be rusted to the shaft and need a little work to free up. Also on the rear, notice the shaft has a punch mark on it that lines up with the lever a certain way. Take note where the mark is and install the new lever the same way.
  • RonKZ650
  • RonKZ650's Avatar
07 May 2008 10:06
#211791
Vach, you got cable brakes on yours?:laugh:
  • vach
  • vach's Avatar
07 May 2008 13:13
#211846
lol.. I meant remove the cable from the front brake lever.:lol:
  • donthekawguy
  • donthekawguy's Avatar
07 May 2008 23:12
#211986
He must have the old front drum cable operated brakes. :laugh: BTW take the screw out remove the lever put new lever in replace bolt. Easy peasy.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
