Just wondering....
  • MCH650SR
  • MCH650SR's Avatar Topic Author
Just wondering....
05 May 2008 16:10 - 05 May 2008 16:11
#211417
On my 650SR I currently have a 15 tooth drive sprocket. I recently purchased this bike and it seemed to have high RPMs for the speed. Granted it is quick off the line; but I'm not comfortable with the high revs at cruise speed. I understand the stock SR came with 16 tooth sprocket. Originally I was thinking of going with a 17 tooth to bring down the rpms; but will 15 to 17 tooth be a huge jump? I would like about 4500 RPMs or less at cruising at about 90 to 100ks; now I'm doing about 5000K to 5500Ks plus.
Note I seem to have the stock sprocket on the rear wheel; 42T.
1979 KZ650SR
modified with BS32 carbs
Yoshimura 4 in1
2006 Kawasaki Sherpa
1979 Honda CX500
BC Canada
Last edit: 05 May 2008 16:11 by MCH650SR.
  • sramsey216
  • sramsey216's Avatar
Re: Just wondering....
05 May 2008 16:25
#211418
17T will lower torque but improve you gas mileage. Here is a gear ratio chart for your reference. Hope this helps.
www.jtsprockets.com/fileadmin/files/jtgearratio.pdf
1980 KZ1000 LTD
  • MCH650SR
13 May 2008 08:34
#213290
Well I installed the 17T front sprocket and am glad I did. There is a significant drop in RPMs at cruising. At 110Ks it's revving at about 5500RPM. Before I was doing 90K at those revs with the 15T sprocket.
I think I got soaked from the dealer for the OEM Kawasaki sprocket. $80 CAD. Supposedly it has some noise dampening feature. But all I see are two 3/8" holes drilled in the sprocket. But I am very satisfied with the result.
1979 KZ650SR
Yoshimura 4 in1
1979 Honda CX500
BC Canada
