Is a KZ750E1 suppossed to have steering stops?
  • po boy
  • po boy's Avatar Topic Author
05 May 2008 13:54 - 05 May 2008 13:55
#211398
Reason I'm asking, is I have a dent on both sides of the very front of my otherwise pristine gas tank....
I can flop the forks to either side and hit the tank.
I can see tabs on the bottom of the steering stem that look like they're suppossed to hit something, but nothings there for them to rest on.
Arrrrrrrgggg!!!
1980 KZ750E1
2002 Hayabusa
Last edit: 05 May 2008 13:55 by po boy.
  • JR
  • JR's Avatar
Re: Is a KZ750E1 suppossed to have steering stops?
05 May 2008 15:08
#211406
Yes there should be steering stops. The tabs are supposed to hit a post just behind the bottom of the steering stem. See the pic below. I have dings in the tank where the PO had put on some kind of lowered bars or cafe bars. These were hitting the tank before the steering stops (tabs) hit the post. Hope this helps.
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
05 May 2008 15:46 - 07 Feb 2013 03:19
#211413
79 KZ1000ST
Past:
Many.
Last edit: 07 Feb 2013 03:19 by KZ250LTD.
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
05 May 2008 19:16
#211456
The "missing post" thing is a common affliction of 70's Kwaks, both 2 and 4 strokers. It seems that the weld bead holding the post in place is not of stellar quality and it doesn't take much of a hit to knock it loose. That little post is a "Top 10" item to check when buying a used Kwakker from that era, IMO. Missing/smacked post ??? Price takes a big nose dive because the bike has had front end damage at some time in its past. The front end MAY be okay NOW, but it has been in some kind of accident in its past. Further investigation is required. Who knows what other little secrets that particular bike is hiding ??
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
05 May 2008 20:20
#211475
So what's actually HITTING the tank?
If it's the bars...are they factory,or aftermarket?
Some of the aftermarker bars WILL touch the tank.
1977 KZ1000 A-1
  • po boy
05 May 2008 20:52
#211485
It's the fork tubes that are hitting the tank.
Crap...
1980 KZ750E1
2002 Hayabusa
  • po boy
05 May 2008 20:54
#211486
Yep, there's big hole where that knob's suppossed to be.
That's not the kinda part you can order either.
Maybe I can fab something up.
I'm cussing a blue streak. Tank's otherwise perfect, painted british racing green.
1980 KZ750E1
2002 Hayabusa
05 May 2008 21:14
#211490
Maybe tap the hole and use an allen bolt. :)
  • KZ250LTD
  • KZ250LTD's Avatar
Re: .
05 May 2008 23:26 - 07 Feb 2013 03:19
#211511
79 KZ1000ST
Past:
Many.
  • po boy
06 May 2008 18:36
#211656
No front end damage here.
I highly suspect it either came off because it was defective, or the dummy that had the bike in Arkansas before me took it off on purpose...
Gonna fab up something to stick in there.
1980 KZ750E1
2002 Hayabusa
