78' KZ650 Swing Arm Conversion
- Realnoisy
04 May 2008 20:02
I just landed a parts bike. A 83' KZ750 with mags and disc brakes. I would like to convert my 78 KZ650 to accept these wheels.
On my donor bike there is a bracket bolted to the frame for the brake pedal assembly. My KZ650’s brake pedal is bolted to the frame. Will I need to drill into my frame to attached the bracket assembly from the donor bike or can I somehow set it up the disc brakes with the current brake assembly that is stock on my KZ650?
- rstnick
Re: 78' KZ650 Swing Arm Conversion
05 May 2008 06:30
You will need to mount the master cylinder (MC) either with a brcket and some bolts, or some have had a tab welded onto the frame to mount the MC.
Also the brake rod and linkage will need to be changed from your drum brake version to the disk's rod etc.
The 750's parts may just swap over, or you can possibly find some on ebay or from someone here. I think I may even have those parts from what's left of my 650c3.
Oh and swap on the front fender also, as I see yours is missing. The front fender acts as a brace as well, and you need that support or your front end could get squirly.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Qdude
- It is all good.
05 May 2008 10:08 - 05 May 2008 10:09
Gotta agree with him there. Physics of it make sense.
77 KZ 650 C1.
77 KZ 650 C1.
77 KZ 650 C1.
Last edit: 05 May 2008 10:09 by Qdude.
- Realnoisy
05 May 2008 15:41 - 05 May 2008 15:52
Thanks for the info! Here is a picture of what I am tryimg to explain. I'm not sure if I can use this KZ750 setup on my KZ650 as I would have to drill holes in my frame to attach the brake assembly plate.
The fenders are missing because I am refinishing them. The bike was Mary Kay pink and I just had to change it on my profile!
Last edit: 05 May 2008 15:52 by Realnoisy.
- rstnick
07 May 2008 15:44
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
