Maximum Rear Tyre Size
- philrad
01 May 2008 21:57
Help ?
What is the maximum size rear tyre I can fit without it fouling the chain guard or swing arm to a 1980 Z650F with a standard swing arm and standard 18 inch rim. Thanks for any information that might be forth coming.
Phil
1980 Z650
2004 Triumph Daytona
Phil
1980 Z650
- StreetfighterKz
Re: Maximum Rear Tyre Size
02 May 2008 04:28
Have you tried the "Search Forum" function at the top of the page. If you can't find anything a good rule of thumb is one size larger. For example if you bike takes a 120/90-18, then you could go to a 130/80-18. If you try to squeeze to big a tire you're going to mess up handling and traction...not recommended.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
