KZ750 single disc spoked rear wheel.... what year arm/axle/brake caliper?
- caffcruiser
01 May 2008 18:36
I'm assuming the mag and spoke rears are different years and sizes?
I have a wheel with tire and everything for the rear, but it's missing the sprocket/carrier. I was going to just get a new sprocket and then an arm, brake caliper, and axle and convert my 650 to a single rear disc.
- Aesop
Re: KZ750 single disc spoked rear wheel.... what year arm/axle/brake caliper?
01 May 2008 19:20
I used a 750B Twin wire rim that accepts a disc. Unfortunatly I did not pick up thr cush drive, damper, and axle because i thought the 650 stuff would work. It does not. If you do this, buy the entire setup. I am having a hard time finding the parts I need.
- PLUMMEN
01 May 2008 20:24
kz1000 77-78 the same???????:huh:
- caffcruiser
02 May 2008 04:07
Aesop wrote:
Of course they are not the same. One is a disc hub, the other is a drum.
I've got the wheel, cush drive, brake rotor, etc.
Just need sprocket and carrier and the arm setup.
Hello Ebay!
Hello Ebay!
- Aesop
02 May 2008 09:44
Not so. The 650 I have is a disc mag wheel, but the cush drive will not work in a 750 wire wheel w/ disc. The axle is also a different diameter.
